I needed a case designed to hold the BeagleBone Black and 4D Systems 4.3" LCD Touchscreen. It is designed to sit on a desk and have the screen angled towards the user. This was one of the prototypes. I went with a different design than this, so I figured I would release this one to the public if anyone wants it.
It was designed by a member of Reddit /u/ubermeisters, a moderator on /r/3dprinting. He is a talented designer, and charges a very reasonable price. If you need something designed, I can highly recommend him.
Anyway, here are some renders of the design:
BeagleBone Black & 4D Systems LCD
Just some things you need to be aware of. This case requires a low profile power adapter, and a small wifi adapter. This is what I’ll be using:
Edimax EW-7811Un
Winford Engineering
The case is held together by press-in screw inserts, which you will probably have to glue in. You’ll then need screws for it. Just an FYI, part of the reason I didn’t go with this design is because I could only find these inserts in bulk quantities.
Yardley Press-in Screw Inserts
M3x.5x10mm Screws
The power cord will fit through the hole in the back.
You can have it printed on http://www.makexyz.com/ for ~$30-$50 depending on the person you use, and if they’re local or not, as well as any other 3D printing services.
Anyway, here are the files if you want them:
