I messed up my BBB boot by upgrading the kernel. Help!
Hi everyone!
I’m looking for some enlightenment to solve the problem I have with my BBB.
It was running fine until I tried to follow this guide for setting up the WiFi dongle.
https://learn.adafruit.com/setting-up-wifi-with-beaglebone-black?view=all
One of the steps suggested to do the following:
1. cd /opt/scripts/tools/
1. ./update_kernel.sh
I did and it worked (well, it didn't show error messages). But after the reboot nothing happens :( It starts double-blinking with one of the user LEDs and that's it, no network, no image on the screen.
Any idea how to revert that upgrade of repair it?
I can get to the filesystem by booting with fresh image on uSD card but I'm sure what to do with it... My experience with Linux doesn't go that far :(
I'd appreciate any hints!
Thanks!
Olex
Do you have a usb-serial adapter to plug into J1?
https://elinux.org/Beagleboard:BeagleBone_Black_Serial
Using that, it would be useful to see what the board is doing on
bootup, to help assist you to fix it.
Hi Robert,
Thanks for your answer!
Here is the output of the console:
U-Boot SPL 2017.07-00002-gd316f5106c (Jul 11 2017 - 10:43:17)
Trying to boot from MMC2
U-Boot 2017.07-00002-gd316f5106c (Jul 11 2017 - 10:43:17 -0500), Build: jenkins-github_Bootloader-Builder-585
`CPU : AM335X-GP rev 2.1` `I2C: ready` `DRAM: 512 MiB` `No match for driver 'omap_hsmmc'` `No match for driver 'omap_hsmmc'` `Some drivers were not found` `Reset Source: Power-on reset has occurred.` `MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1` `Using default environment`
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] ...
board_rev=[00C0] ...
Card did not respond to voltage select!
mmc_init: -95, time 13
mmc_init: -95, time 12
switch to partitions #0, OK
Scanning mmc 1:1...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
Checking for: /boot/uEnv.txt ...
2171 bytes read in 15 ms (140.6 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.4.145-bone23 ...
8263240 bytes read in 549 ms (14.4 MiB/s)
loading /boot/dtbs/4.4.145-bone23/am335x-boneblack.dtb ...
51343 bytes read in 51 ms (982.4 KiB/s)
uboot_overlays: add [enable_uboot_overlays=1] to /boot/uEnv.txt to enable...
loading /boot/initrd.img-4.4.145-bone23 ...
5935511 bytes read in 404 ms (14 MiB/s)
debug: [console=ttyO0,115200n8 root=/dev/mmcblk1p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 quiet consoleblank=0 fbcon=rotate:1 omap_wdt.nowayout=0 root=/dev/mmcblk0p1 root=/dev/mmcblk0p1] ...
debug: [bootz 0x82000000 0x88080000:5a9197 0x88000000] ...
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8fa56000, end 8ffff197 ... OK
Loading Device Tree to 8fa46000, end 8fa5588e ... OK
`Starting kernel ...`
[ 0.000690] clocksource_probe: no matching clocksources found
[ 4.085697] omap-sham 53100000.sham: initialization failed.
[ 4.104156] omap_voltage_late_init: Voltage driver support not added
Gave up waiting for root device. Common problems:
- Boot args (cat /proc/cmdline)
- Check rootdelay= (did the system wait long enough?)
- Check root= (did the system wait for the right device?)
- Missing modules (cat /proc/modules; ls /dev)
ALERT! /dev/mmcblk0p1 does not exist. Dropping to a shell!
BusyBox v1.22.1 (Ubuntu 1:1.22.0-15ubuntu1) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs)
I see that problems started already here, even before loading the kernel :
If I understand correctly it can't detect eMMC device.
Do you have any idea why?
Thanks again!
Best,
Olex
Hi Robert,
Awesome thanks!
That's ^ actually your microSD card.. It might be toast..
Scanning mmc 1:1...
why do you have 3 "root=?" options, the first is set by u-boot, but
the second two are user created from /boot/uEnv.txt
Your microSD card might be toast...
