Hi All,
I need a tutorial to boot linux in bbb.
I have booted 3.8 I have rootfs and boot partition
I have booted using a prebuild debian image
I see there is only one rootfs iin debian image
why there is difference between having boot and rootfs vs a single rootfs folder.
I want to use latest kernel. I ran ./build.sh script and it did what it can do. I have now a zImage unlike a vmlinuz in the debian boot image. Why this difference?
How can I prepare a booting sd card using ./build.sh script and boot on my BBB.
took u-boot just now from this tutorial,
two problems I see while compiling
Your GCC is older than 6.0 and will not be supported starting in v2018.01.
and
lib/asm-offsets.c:1:0: error: bad value (armv5) for -march= switch
Why such errors?
Can’t we use older u-boot that used to work?
Umm that statement is pretty obvious from u-boot, what’s your issue with it?
Didn’t pass ARCH=arm
Both those errors show you didn’t follow the directions as written.
yes, i didn’t followed instructions, for cross compiler.
I already have a cross compiler that I am using and that builds u-boot.
A couple of more questions,
I took this kernel For am33x-v4.4 (Longterm 4.4.x):
There is another thing on this site
1. TI BSP
What its for?
- I took this capemgr: v4.4.x+
When I issued this
./install.sh
I get an error Error: this script: [./install.sh] is not supported to run under [x86_64]
TI has their own supported kernel fork, those are based on that.
Correct, that script is not supported to be run on your desktop…
Run it in the end Beagle device.
I am at menuconfig menu in terminal, I don’t know where is bb.org_defconfig. Which configuration I choose for .config file to get booted on my BBB.
Umm just hit esc-esc the default config is already loaded by default. Menuconfig pops up just so you can see, tweak, etc…
Why i asked this because except I am downloading kernel from Robert’s repository I don’t know where beaglebone configs are
selected.
I can only see the soc name like am3xx but no where in configs beaglebone or anything that does not confuse a first timer
sure that he is doing the right thing.
also why would I use TI’s BSP? Is it important for a first timer?
The default config is located at…
patches/defconfig
It gets copied to ./KERNEL/.config
Before
make menuconfig
Gets called…
It’s important to TI and some users, it’s also what we ship by default for BeagleBoard.org images.
#1 You WERE talking to Robert
#2 There is no question if Robert did "the right thing". The question is if
YOU did the right thing.
I don’t know if I am doing the right thing that’s why I am posting questions.
