Well I'm back at home off my boat now and I didn't manage to get
Debian 9 onto my BBB there, it's still running Debian 7.
I still have remote access to the BBB from here at home so, if anyone
wants to help and needs answers to questions I can go and take a look.
The Debian 9 image I was trying was this one (expanded of course) :-
bone-debian-9.3-iot-armhf-2018-01-28-4gb.img.xz
As noted in my previous postings here this image successfully
self-installed automatically on another (I thought older) Debian 7 BBB
that I had.
When inserted in the BBB I want to update it did nothing on rebooting.
I also tried powering up with the 'boot' button held down but that did
no good either, it simply did nothing.
I tried running the script:-
/opt/scripts/tools/beaglebone-black-eMMC-flasher.sh
and that didn't work either (as reported above in an earlier posting),
it seems to have done something to the microSD which had Debian 9 on
it too.
So, how on earth am I going to get Debian 9 onto my BBB? Surely there
must be a reliable way to do this, especially as I have a running
Debian system on it. Is there a script I can get which can install an
OS from an image on a microSD? I'd really be happiest with a
script/program I can load and run on my existing system rather than
some sort of automatic load which requires a combination of buttons
pressed and power-up sequences.
What I need (help/information) is:-
What Debian 9 image to use (minimal non-GUI system)
How to write it to the microSD card (on a Linux system)
A script to run that will install it on the eMMC.
With: bone-debian-9.3-iot-armhf-2018-01-28-4gb.img.xz booted on the microSD
Run:
sudo /opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
It should "work", but there is a good reason we moved to flashing the
eMMC in single user mode...
So IF it fails, follow the standard eMMC flashing directions here:
https://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Flashing_eMMC
On Wed, 4 Apr 2018 20:52:50 +0100, Chris Green
<cl@isbd.net> declaimed the following:
"nothing"? Did it even boot?
it too.
Given what I could understand of the script (I'm no where near a BASH
script expert -- my heaviest "shell script" experience is VAX/VMS DCL,
AREXX [Amiga REXX]... I don't consider Python a "scripting language" (AREXX
could be used to control any application that opened an AREXX message port,
and any statement in a script that did not parse as native AREXX would be
sent to the current "command host" -- ie; the shell by default or an
application if one did "address application-name" first -- and the easiest
way to make a statement "not native" was to quote the first word) -- pardon
the harangue -- I understand the script to copy files from the /booted/
system media to the other media. If it booted from the eMMC, running the
script will copy the eMMC to the SD card.
I could be all wet with that hypothesis <G>
Boot with your existing system. Insert the SD card. MOUNT the SD card
if it isn't automatically mounted (there was a period of time where the
Wheezy images would auto-mount SD cards).
Edit the <SDCARDMOUNT>/boot/uEnv.txt file (NOT a file on the eMMC) as
described Latest Software Images - BeagleBoard
Reboot. If the reboot doesn't read the SD card a start flashing, reboot
with the boot button held down! Due to the changes in device tree handling
since Wheezy, a Wheezy era eMMC uBoot may not be compatible (hypothesis --
I don't think I've used the boot button since Wheezy) and my understanding
is that the boot button totally bypasses the eMMC uBoot for the one on the
SD card (newer versions, I believe, use the eMMC uBoot which transfers to
the SD card if installed to complete the boot).
No, it didn't even boot, the single (power?) LED came on but that was
all. Had me worried for a minute but without the boot button down it
acted quite normally still and booted Debian 7,
>it too.
I think you're spot on actually! I didn't stare all that hard
at the code but it certainly did seem to copy from the eMMC to the
microSD card.
Yes, my Debian 7 does automount SD cards.
OK, thanks, that does seem to make sense to me. I'll need to wait
until I'm next back on the boat which will be a week or so now. The
boat is in France and I'm in England, it's not just down the road!
Thanks for continuing to help Robert.
Run:
I don't have that script in the existing Debian 7 installation:-
chris@odin:~$ ls /opt/scripts/tools/eMMC
beaglebone-black-make-microSD-flasher-from-eMMC.sh
chris@odin:~$
Should I run it from the mounted Debian 9 image?
Beagleboard:BeagleBoneBlack Debian - eLinux.org
OK, thank you.
As I said above I'm away from the boat for a while now, I should be
able to retry in a week or two.
ALL the scripts assume you are directly "running" the image from a
fresh bootup, that you would like to "copy" to the secondary storage.
Don't do anything fancy beyond that.
OK, thanks, that's all I needed to know (I hope).
