I am having a problem with my Beaglebone black interfacing with a BH1750 light sensor (am using a breakout board). When I connect, via wire, the light sensor to the 3.3 volt (p9 port 3) and the ground (p9 port 1) as well as the clock and data (p9 port 19 and 20), the beaglebone is not able to detect the light sensor at the appropriate address (or at all).
I followed these steps:
-Update Beaglebone I2C files
-Connect the ground and the 3.3V Vdd lines (header p9 1 and 3)
-Connect the Clock and data lines (header p9 19 and 20)
-Check for the light sensor using: sudo i2cdetect -r # (# = 0 and 1, we checked both I2C buses to be sure).
These steps were pulled from this site:
http://bozontlabs.blogspot.com/2014/09/beaglebone-black-and-bh1750-light-sensor.html
Does anyone know what might the reason be for not detecting the BH1750 or how I might go about debugging the issue?
Thanks for the help in advance!
