I want to manage the I2C1 module by the PRU, in order to interface some I/O expanders (MCP23017 by Microchip).
I use may own “cape” without the plug-n’ play eeprom (one of the next steps will be adding management for DCAN0 and DCAN1 so i’ll need these pins too…).
So, at present, there are just 2 MCP23017 connected to the P9.17 and P9.18.
I load the cape-universal into slots and then I use configure-pin command to set P9.17 and P9.18 as i2c
I’ve started from an example into the am335x_pru_package-master and wrote my own C PRU loader.
Very simple, it just:
loads the PRU code
init the data exhanged with the PRU
start the PRU
wait for ESC key press
signal to the PRU to stop
wait for the PRU stop
exit.
Also the assembly PRU code is simple:
init I2C1 module (by writing registers PSC, SCLL, SCLH, CON)
init 1st I/O expander as 16 inputs (even if at power on it’s already set as input)
init 2nd I/O expander as 16 outputs
cicle reading status of inputs from 1st expander and echoing to the outputs of 2nd expander
exit cycle and halt when receive stop flag from the loader
for send and receive I2C messages I use register SA, CNT, DATA and CON.
That’s very simple and linear… pity, it doesn’t work.
I didn’t see any activity at all in P9.17 and P9.18.
The PRU code is surely running, as I add a cycle counter and show it in the loader while it’s waiting for ESC keypress, and also the PRU code correctly stops at the loader command.
I was expecting that the PRU code stalls if I2C bus doesn’t work, as there are waiting cycles both for STOP condition or for CNT reaching zero (depending on the write or read message sending).
But it seems running, and running very fast also: the cycle counter is incremented to a very fast rate (over 550 kcycles/s) that’s not compatible with the correct executing of I2C sequences (I’ve setted the module for 400Kbps rate… so the PRU cycle it’s even faster than a single I2C bit time!).
I’m surely doing something wrong, but I cant fugure what.
Any idea?
Suggestions?
Inserisci qui il codice...
.origin 0
.entrypoint START
#include “iic_ioexp.hp”
//costanti per l’accesso al modulo I2C1
#define I2C1_BASE C2 //base registri I2C1 nella tabella costanti
#define I2C_SYSC 0x10 //offset del registro I2C_SYSC
#define I2C_STAT_RAW 0x24 //offset del registro I2C_STATUS_RAW
#define I2C_SYSS 0x90 //offset del registro I2C_SYSS
#define I2C_CNT 0x98 //offset del registro I2C_CNT
#define I2C_DATA 0x9C //offset del registro I2C_DATA
#define I2C_CON 0xA4 //offset del registro I2C_CON
#define I2C_SA 0xAC //offset del registro I2C_SA
#define I2C_PSC 0xB0 //offset del registro I2C_PSC
#define I2C_SCLL 0xB4 //offset del registro I2C_SCLL
#define I2C_SCLH 0xB8 //offset del registro I2C_SCLH
#define I2C_CMD_ENABLE 0x8400 //modulo I2C abilitato come master
#define I2C_CMD_TX 0x0200 //modulo I2C in trasmissione
#define I2C_CMD_RX 0x0000 //modulo I2C in ricezione
#define I2C_CMD_START 0x0001 //modulo I2C richiesta generazione sequenza START
#define I2C_CMD_STOP 0x0002 //modulo I2C richiesta generazione sequenza STOP
//costanti per l’accesso all’I/O expander MCP23017
#define IO_EXP0 0x20 //7bit I2C address dell’I/O expander 0 (ingressi)
#define IO_EXP1 0x21 //7bit I2C address dell’I/O expander 1 (uscite)
#define IO_EXP_IODIRA 0x00 //indirizzo registro IODIRA dell’I/O expander
#define IO_EXP_GPIOA 0x12 //indirizzo registro GPIOA dell’I/O expander
//macro che attende fine sequenza verificando generazione seqeunza di STOP
.macro I2C_WAIT_BY_STOP
_CHECK:
LBCO r1.w0, I2C1_BASE, I2C_CON, 2
QBBS _CHECK, r1.t1
.endm
.macro I2C_WAIT_BY_COUNT
_CHECK:
LBCO r1.w0, I2C1_BASE, I2C_CNT, 2
QBNE _CHECK, r1.w0, 0
.endm
START:
// clear that bit
LBCO r0, C4, 4, 4
CLR r0, r0, 4
SBCO r0, C4, 4, 4
//configurazione modulo I2C1
//reset del modulo I2C1
MOV r1.w0, 0x0002
SBCO r1.w0, I2C1_BASE, I2C_SYSC, 2
MOV r1.w0, 0x0000
// //attesa fine reset modulo
//_WAIT_RDONE:
// LBCO r1, I2C1_BASE, I2C_SYSS, 4
// QBBC _WAIT_RDONE, r1.t0
//configura prescaler e durata SCL H/L per avere 400kHz
MOV r1.b0, 4 //prescaler=4+1 → ICLK=SCLK/prescaler=100/5=20MHz (nel reference manual raccomandano circa 24Mhz)
SBCO r1.b0, I2C1_BASE, I2C_PSC, 1
MOV r1.b0, 18 //durata SCL L=18+7 → tLOW=1/ICLK*(SCLL+7)=1/20E6*(18+7)=1.25us
SBCO r1.b0, I2C1_BASE, I2C_SCLL, 1
MOV r1.b0, 20 //durata SCL H=20+5 → tHIGH=1/ICLK*(SCLH+5)=1/20E6*(20+5)=1.25us
SBCO r1.b0, I2C1_BASE, I2C_SCLH, 1
//abilita modulo
MOV r1.w0, I2C_CMD_ENABLE
SBCO r1.w0, I2C1_BASE, I2C_CON, 2
//inizializzazione IOEXP 0
//indirizzo slave
MOV r1.w0, IO_EXP0
SBCO r1.w0, I2C1_BASE, I2C_SA, 2
//n. byte da spedire
MOV r1.w0, 3
SBCO r1.w0, I2C1_BASE, I2C_CNT, 2
//riempie FIFO
MOV r1, IO_EXP_IODIRA | 0x00FFFF00 //tutti i pin come ingressi (in realta’ e’ gia’ cosi’ dal POR)
SBCO r1.b0, I2C1_BASE, I2C_DATA, 1
SBCO r1.b1, I2C1_BASE, I2C_DATA, 1
SBCO r1.b2, I2C1_BASE, I2C_DATA, 1
//attesa bus free
_WAIT_BB:
LBCO r1, I2C1_BASE, I2C_STAT_RAW, 4
QBBS _WAIT_BB, r1.t12
//comando scrittura
MOV r1.w0, I2C_CMD_ENABLE | I2C_CMD_TX | I2C_CMD_START | I2C_CMD_STOP
I2C_WAIT_BY_STOP
//inizializzazione IOEXP 1
//indirizzo slave
MOV r1.w0, IO_EXP1
//n. byte da spedire gia’ impostato
//riempie FIFO
MOV r1, IO_EXP_IODIRA | 0x00000000 //tutti pin come uscita
//comando scrittura
I2C_WAIT_BY_STOP
//ciclo rinfresco I/O
_LOOP:
//legge ingressi
//indirizzo slave
MOV r1.w0, IO_EXP0
MOV r1.w0, 1
//riempie FIFO
MOV r1, IO_EXP_GPIOA
//comando scrittura
I2C_WAIT_BY_COUNT
//n. byte da ricevere
MOV r1.w0, 2
//comando lettura
MOV r1.w0, I2C_CMD_ENABLE | I2C_CMD_RX | I2C_CMD_START | I2C_CMD_STOP
I2C_WAIT_BY_STOP
//legge i byte ricevuti
LBCO r2.b1, I2C1_BASE, I2C_DATA, 1
LBCO r2.b2, I2C1_BASE, I2C_DATA, 1
//scrive uscite
//indirizzo slave
MOV r1.w0, IO_EXP1
MOV r1.w0, 3
//riempie FIFO
MOV r2.b0, IO_EXP_GPIOA
SBCO r2.b0, I2C1_BASE, I2C_DATA, 1
//comando scrittura
I2C_WAIT_BY_STOP
LBCO r2, CONST_PRUDRAM, 0, 4
ADD r2, r2, 1
SBCO r2, CONST_PRUDRAM, 0, 4
//esce dal ciclo e se il flag di uscita nella ram condivisa e’ azzerato
LBCO r2, CONST_PRUDRAM, 4, 1
QBNE _LOOP, r2.b0, 0
_EXIT:
//invia all’host la notifica di programma completato
MOV R31.b0, PRU0_ARM_INTERRUPT+16
HALT
