1 - i2c was installed by default in my install of the latest factory image…some notes though on the the i2c busses:
i2c-0 is used by some on-board devices
i2c-1 does not yet seem to be supported by the kernel
i2c-2 actually uses the kernel’s /dev/i2c-1 located on p9 with pins 19,20
list chips on i2c bus (should report a device): i2cdetect -r
get data from i2c device (should give data): i2cget [register] [b|w]
eg for a TMP102 device with ADDR0 pin tied to GND on I2C-2:
“i2cdetect -r 1” shows device at 0x48
“i2cget 1 0x48 0 w” shows 0xa019 = 0x19a = 25.6C = 78F
It’s worth noting that the i2c driver names the /dev/ files. So it’s only incidental that /dev/i2c-1 points to the i2c-2 pins. Generating a new device tree that configures all three i2c peripherals should cause a /dev/i2c-2 to get created.
