I have Li-5M03 rev 3.1 and BB-xM rev C2.
root@beagleboard:~# uname -a :
Linux beagleboard 2.6.32 #3 PREEMPT Tue Jul 26 10:56:56 CEST 2011 armv7l unknown
I have follow this instructions to install kernel and have a mt9p031 working (http://caganarslan.wordpress.com/2013/07/04/second-post/).
I can take snapshot and video with :
mplayer tv:// -tv driver=v4l2:width=1280:height=720:device=/dev/video0:fps=5 -vo jpeg
or
mplayer tv:// -tv driver=v4l2:width=640:height=480:device=/dev/video0:fps=10 -vo x11
And it works perfectly.
But i have a problem, i can’t read/write in register with i2c-tools. I have tried :
root@beagleboard:~# i2cdetect -r 2
WARNING! This program can confuse your I2C bus, cause data loss and worse!
I will probe file /dev/i2c-2 using read byte commands.
I will probe address range 0x03-0x77.
Continue? [Y/n] y
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – -- – -- – -- – -- – -- – -- –
10: – -- – -- – -- – -- – -- – -- – -- – --
20: – -- – -- – -- – -- – -- – -- – -- – --
30: – -- – -- – -- – -- – -- – -- – -- – --
40: – -- – -- – -- – -- UU – -- – -- – -- –
50: – -- – -- – -- – -- – -- – -- – -- – --
60: – -- – -- – -- – -- – -- – -- – -- – --
70: – -- – -- – -- – --
Sensor is well detect on 0x48 address.
But when i tried to modify gain or exposure, i get :
root@beagleboard:~# echo 22 > /sys/devices/platform/i2c_omap.2/i2c-2/2-0048/gain_val
[ 3638.106781] mt9p031 2-0048: Error setting gain.-121
[ 3638.111511] mt9p031: Global gain write failed
root@beagleboard:~/Desktop# dmesg | grep mt9
[ 3304.832366] mt9p031 2-0048: mt9p031 chip ID 1801
root@beagleboard:~/Desktop# i2cget -y 2 0x48 000 w
Error: Could not set address to 0x48: Device or resource busy
Any ideas ?
Thank you
