someone know if is posible to use the I2C2 as a bus slave? I read
somewere that only support master mode? is that true? any trick?
I need to use it in both directions.
somewere that only support master mode? is that true? any trick?I need to use it in both directions.
According to the TRM chapter 18.1 I2C1, I2C2 and I2C3 all support both
multi-master and slave modes.
Only I2C4 is limited to be a single master only bus-controller...
I don't know what is supported by the Linux driver, but the HW should have
no problems...
Søren
no problems...
Kernel docs, Documentation/i2c/summary says:
"At this time, Linux only operates I2C (or SMBus) in master mode; you can't
use these APIs to make a Linux system behave as a slave/device, either to
speak a custom protocol or to emulate some other device."
