If have someone success in dsp-brigde or dsp-link,please help me; thank a lot;
i have do follow "http://elinux.org/BeagleBoard/DSP_Howto#ping_test"
and "http://elinux.org/BeagleBoard/gst-openmax"; and i used the
tiopenmax-3.5 instead of tiopenmax-3.0;
but i am failed;
the erorr message is bellow;
oot@beagleboard:~# ./play.sh
0:00:00.339111327 1174 0x15078 WARN GST_PLUGIN_LOADING
gstplugin.c:502:gs
t_plugin_load_file: module_open failed: /usr/lib/gstreamer-0.10/
libgstsubparse.s
o: undefined symbol: parse_sami
(gst-launch-0.10:1174): GStreamer-WARNING **: Failed to load plugin '/
usr/lib/gs
treamer-0.10/libgstsubparse.so': /usr/lib/gstreamer-0.10/
libgstsubparse.so: unde
Setting pipeline to PAUSED ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
****************LCML ERROR : DSP ************************
Error: Create the Node : Err Num = 8000803d
0:00:00.731842032 1173 0x149350 ERROR omx_util
gstomx_util.c:929:
EventHandler: unrecoverable error: 80001009
0:00:00.732421866 1173 0x142268 WARN omx
gstomx_base_filter
.c:702:pad_chain:<omxmpeg4dec0> error: Error from OpenMAX detected
ERROR: from element /GstPipeline:pipeline0/
GstOmxMpeg4Dec:omxmpeg4dec0: GStreame
r encountered a general stream error.
Additional debug info:
gstomx_base_filter.c(702): pad_chain (): /GstPipeline:pipeline0/
GstOmxMpeg4Dec:o
mxmpeg4dec0:
Execution ended after 141235353 ns.
Setting pipeline to READY ...
Setting pipeline to NULL ...
FREEING pipeline ...
0:00:00.762725824 1173 0x142268 WARN avidemux
gstavidemux.c:4153
:gst_avi_demux_loop:<avidemux0> error: Internal data stream error.
0:00:00.768859858 1173 0x142268 WARN avidemux
gstavidemux.c:4153
:gst_avi_demux_loop:<avidemux0> error: streaming stopped, reason error
0:00:00.769989008 1173 0x142268 WARN avidemux
gstavidemux.c:4161
0:00:00.770385737 1173 0x142268 WARN avidemux
gstavidemux.c:4161
:gst_avi_demux_loop:<avidemux0> error: downstream did not handle EOS
