IGEPv2 board
Seems like they have finally started selling IGEPv2 board:
http://www.igep-platform.com/
It looks like a nice beagleboard clone with upgraded RAM and more peripherals
on board.
Could any of the early adopters test whether it has a stable USB host
(reliable enough to use with an external HDD)?
Op 24 sep 2009, om 15:53 heeft Siarhei Siamashka het volgende geschreven:
What has been upgraded on the ram front? Looks like the same RAM/NAND chip to me.
regards,
Koen
According to the webpage and the hardware manual:
"4Gb NAND/ 4Gb Mobile Low Power DDR SDRAM @ 200 Mhz (Package on Package - PoP
technology)"
Which looks like quite a big improvement in terms of both size and
performance.
Op 24 sep 2009, om 16:30 heeft Siarhei Siamashka het volgende geschreven:
Could this be 4Gigabit NAND and 4 Gigabit RAM, which when divided by 8 bits/byte becomes 512MByte NAND and 512MByte RAM ??
Charles
geschreven:
geschreven:
chip to me.
Package - PoP
technology)"
performance.
Indeed, I was looking at the "board size" picture, which has the exact
same "J192" PoP as on my beagles :slight_smile:
regards,
Koen
The preliminary hardware reference says it has 512 MBytes LPDDR SDRAM –
200 Mhz and 512 Mbytes nand flash
So it shourd be It
Also as that fact figure in the changelog it is possible the size
comparison is a photo of an older version, before they switched to a
bigger ram/flash module.
hi here,
I received my igepv2 board EVK last week....yes it comes with
512Mbytes onenand flash.
This EVK comes with poky distribution on nandflash.
Mike
I need to use WIFI for my iphone project I am planing to purchase
IGEPv2 Board - O3530 - RB Series 600 mhz
or
http://www.gumstix.com/store/catalog/product_info.php?products_id=203
and I am not familar to Linux and I dont wana waste my time for
looking for correct drivers.
Which one i should buy?
Did you try wifi on your board?
Do I need to buy MicroSD 2G - Ubuntu Demo Image for 10.0€ ? to run
Linux? Can I create it my-self?
How long does it take to boot up Linux?
They dont have a good return policy and it may take upto 3 weeks to
ship to product and i dont wana waste my time on it
You if guys help me I will be appreciated.
sel.
140.0€ 119.0€
Save: 15% off
IGEPv2-RB board based on OMAP3530@600Mhz with 512MB RAM, 512MB ONENAND-
FLASH, ETHERNET, WIFI, BLUETOOTH 2.0, USB HOST, USB OTG, MICRO-SD, DVI
and STEREO AUDIO OUTPUT.
Model: IGEP0020-RB1-600Mhz
I recommend you to work with igepv2.
I have some doubts at the beginning regarding the wifi but I found the
answers on myigep forum (www.myigep.com/forum). Wifi works great..
with internal antenna. If you have any problem, ISEE people give you
free support on its forum. You only need to register.
You will also find instructions of how to create de SD on myigep wiki
(wiki.myigep.com) or go directly to http://wiki.myigep.com/trac/wiki/HowToGetTheUbuntuDistribution
Now delivery time is less than 1 week. I now that because I order
another board this week and ISEE Sales inform me that I will receive
it next week.
I have had a very good experience with IGEPv2 board. I recommend you
at least to evaluate one unit.
Mike
