Hello, folks,
I am trying to build my own custom image to boot my beagleboard-xm.
When I pulled latest image-builder from github and tried to run the stript with the command ‘./RootStock-NG.sh -c rcn-ee_console_ubuntu_xenial_armhf’, it ended up with the following error message;
update-initramfs: Generating /boot/initrd.img-4.1.18-ti-r53
Log: (chroot): system_tweaks
Log: (chroot): set_locale
Log: (chroot) Ubuntu: setting up locales: [en_US.UTF-8]
Generating locales (this might take a while)…
en_US.UTF-8… done
Generation complete.
Log: (chroot): manual_deborphan
Log: (chroot): add_user
i2c:x:111:
kmem:x:15:
netdev:x:108:
systemd-journal:x:101:
Log: (chroot) adding admin group to /etc/sudoers
ubuntu:x:1000:1000:Demo User:/home/ubuntu:/bin/bash
passwd: password expiry information changed.
Log: (chroot): startup_script
Log: (chroot): ubuntu_startup_script
qemu: Unsupported syscall: 384
Created symlink /etc/systemd/system/multi-user.target.wants/generic-board-startup.service, pointing to /lib/systemd/system/generic-board-startup.service.
Created symlink /etc/systemd/system/multi-user.target.wants/capemgr.service, pointing to /lib/systemd/system/capemgr.service.
Log: (chroot) Warning, qemu can fail here… (run on real armv7l hardware for production images)
Log: (chroot): [git clone https://github.com/RobertCNelson/boot-scripts /opt/scripts/ --depth 1]
Cloning into ‘/opt/scripts’…
POST git-upload-pack (155 bytes)
POST git-upload-pack (164 bytes)
remote: Counting objects: 119, done.
remote: Compressing objects: 100% (97/97), done.
remote: Total 119 (delta 26), reused 60 (delta 10), pack-reused 0
Receiving objects: 100% (119/119), 298.43 KiB | 204.00 KiB/s, done.
qemu: uncaught target signal 11 (Segmentation fault) - core dumped
error: --shallow-file died of signal 11
fatal: index-pack failed
Log: umount: [/workspace/devel/beagleboard/image-builder/ignore/tmp.oyODR1MpJo/dev/pts]
Log: umount: [/workspace/devel/beagleboard/image-builder/ignore/tmp.oyODR1MpJo/proc]
Log: umount: [/workspace/devel/beagleboard/image-builder/ignore/tmp.oyODR1MpJo/sys]
Log: umount: [/workspace/devel/beagleboard/image-builder/ignore/tmp.oyODR1MpJo/run]
hl1oap@freeman-ubuntu14:/workspace/devel/beagleboard/image-builder$
I used to use earlier version of this script three to four years back without problem, but it does not give me the expected image this time. I tried with all the pre-configured ubuntu configurations (five in total) in the configs/ directory but none of them were successful.
Is there anybody has a clue?
For your information, I am running ubuntu-14.04 LST with Intel i7 core and 16G SDRAM, and the following is the output of ‘uname -a’ command;
Linux freeman-ubuntu14 3.13.0-67-generic #110-Ubuntu SMP Fri Oct 23 13:24:41 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
I also attached the full log of the script running.
Ilkyoung.
image-builder_log.txt (102 KB)
