İmage using narcissus including opencv installation
hi, i wanted to build Angstrom image using narcissus to run opencv on
BeagleBoard. But i could not manage to run OS and therefore,opencv.
I’d be appreciated if you tell me step by step how to build (i mean
what should i select,because there are lots of options, to install and
to run opencv from narcissus web page)image and then, how to compile
and run opencv. Thanks …
Nobady knows the proper way of building an Angstrom image running
Opencv ?
Have checking the opencv checkboxes? I would have assumed that was the obvious starting point....
