Incorrect pinout in Beagleboard xM SRM
Hi everyone!
While developing an expansion board which houses an audio codec interfacing through the audio expansion header i found out that the signals are not on the pins they should be. Then i checked the gerbers and it seems like the SRM of Beagleboard xM is not correct regarding the pinout of this header.
The SRM shows this pinout (bottom view):
On the front page is the contact information for getting the SRM corrected.
Which page? Which Figure?
I will take a look at this when I can and add it to the next revision as needed…
