inotify available?
search for inotify on this board is mostly error output…
  • is it available?
  • Is there something about BBB that makes it incompatible?
  • has anyone compiled from source and got to work?
looked in debian-archive and was unable to find it for stretch… below is from fresh install of bullseye:
debian@BeagleBone:~$ which inotifywait
debian@BeagleBone:~$ sudo apt-get install inotify-tools
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for debian:
Reading package lists… Done
Building dependency tree… Done
E: Unable to locate package inotify-tools
debian@BeagleBone:~$ cat /etc/dogtag
BeagleBoard.org Debian Bullseye IoT Image 2023-09-02
It helps to update your apt cache… sudo apt update
debian@21-am335x-bbb:~$ sudo apt update
Hit:1 http://192.168.1.10/debian bullseye InRelease
Hit:2 http://192.168.1.10/debian bullseye-updates InRelease
Get:3 http://security.debian.org/debian-security bullseye-security InRelease [48.4 kB]
Hit:4 http://repos.rcn-ee.com/debian bullseye InRelease
Fetched 48.4 kB in 4s (11.2 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
debian@21-am335x-bbb:~$ sudo apt install inotify-tools
The following additional packages will be installed:
  libinotifytools0
The following NEW packages will be installed:
  inotify-tools libinotifytools0
0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded.
Need to get 41.6 kB of archives.
After this operation, 106 kB of additional disk space will be used.
Do you want to continue? [Y/n]
gomer reports success, after facepalm
thanks very much.
