Installing a Package on BB
Hi All,
I have a Angstrom file System running on Beagleboard with kernel ver.
2.6.29.
I am trying to install new package on BB ... but am not able to do
so. I tried using 'apt-get install' command but it didn't
worked ...... it seems as if Angstrom doesn't support 'apt-get'
command.
Is there any alternate solution to install a package.
amit
to install use opkg install nome_do_pakote ....
As mentioned, one way is to you need to use the opkg command. You
previously need to download a package file for the application you
want to install (.ipk).
A good source for packages is http://www.angstrom-distribution.org/repo/
Good luck !
that trying to install this package .....
  will be well
  opkg install package_name and ready.
Koen,
Do you think it is worth putting a dummy script in place for “apt-get”, “dpkg”, “rpm” etc that simply outputs a message saying Angstrom uses opkg with a link to a getting started guide as this probably causes a problem for quite a few people when they first start with Angstrom…? (me included :slight_smile:
Mike
