Installing bonescript on beaglebone black ubuntu 3.8.13
I can’t seem to be able to install bonescript on my BBB. I’d appreciate any help. Thanks.
I installed ubuntu because I could not get HDMI to work with Angstrom even with the latest image.
The following is the output when I do “npm install bonescript” -
root@ubuntu-armhf:~# npm install bonescript
npm http GET https://registry.npmjs.org/bonescript
npm http 304 https://registry.npmjs.org/bonescript
bonescript@0.2.3 preinstall /root/node_modules/bonescript
node-gyp clean || (exit 0); node-gyp configure build
make: Entering directory /root/node_modules/bonescript/build' CXX(target) Release/obj.target/misc/misc.o ../misc.cpp:1:0: warning: "BUILDING_NODE_EXTENSION" redefined [enabled by default] <command-line>:0:0: note: this is the location of the previous definition ../misc.cpp:21:27: error: variable or field ‘pollpri_event’ declared void ../misc.cpp:21:27: error: ‘EV_P_’ was not declared in this scope ../misc.cpp:21:46: error: expected primary-expression before ‘int’ ../misc.cpp:32:5: error: ‘ev_io’ does not name a type ../misc.cpp:148:31: error: ‘EV_P_’ has not been declared ../misc.cpp:148:43: error: expected ‘,’ or ‘...’ before ‘*’ token ../misc.cpp: In static member function ‘static void Pollpri::Init(v8::Handle<v8::Object>)’: ../misc.cpp:37:34: warning: statement has no effect [-Wunused-value] ../misc.cpp:38:38: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:47:33: warning: statement has no effect [-Wunused-value] ../misc.cpp: In constructor ‘Pollpri::Pollpri()’: ../misc.cpp:51:49: warning: statement has no effect [-Wunused-value] ../misc.cpp:54:18: error: ‘event_watcher’ was not declared in this scope ../misc.cpp:54:46: error: ‘ev_init’ was not declared in this scope ../misc.cpp:56:9: error: ‘ew’ was not declared in this scope ../misc.cpp: In destructor ‘virtual Pollpri::~Pollpri()’: ../misc.cpp:60:48: warning: statement has no effect [-Wunused-value] ../misc.cpp:63:20: error: ‘EV_DEFAULT_’ was not declared in this scope ../misc.cpp:63:33: error: ‘event_watcher’ was not declared in this scope ../misc.cpp:63:46: error: ‘ev_io_stop’ was not declared in this scope ../misc.cpp: In static member function ‘static v8::Handle<v8::Value> Pollpri::New(const v8::Arguments&)’: ../misc.cpp:67:32: warning: statement has no effect [-Wunused-value] ../misc.cpp:84:49: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:84:55: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:84:73: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:88:53: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:88:73: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:93:56: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:93:60: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:93:63: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:93:83: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:99:43: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:99:47: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:99:64: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:102:48: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:102:52: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:102:55: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:102:74: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:105:22: error: ‘class Pollpri’ has no member named ‘ew’ ../misc.cpp:105:32: error: ‘EV_READ’ was not declared in this scope ../misc.cpp:105:39: error: ‘ev_io_set’ was not declared in this scope ../misc.cpp:106:21: error: ‘EV_DEFAULT_’ was not declared in this scope ../misc.cpp:106:38: error: ‘ev_io_start’ was not declared in this scope ../misc.cpp:111:32: warning: statement has no effect [-Wunused-value] ../misc.cpp: In member function ‘void Pollpri::Event(Pollpri*, int)’: ../misc.cpp:117:57: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:117:61: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:117:67: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:118:23: error: ‘EV_READ’ was not declared in this scope ../misc.cpp:126:43: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:126:47: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:126:64: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:129:48: warning: left operand of comma operator has no effect [-Wunused-value] ../misc.cpp:129:52: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:129:55: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp:129:74: warning: right operand of comma operator has no effect [-Wunused-value] ../misc.cpp: In static member function ‘static void Pollpri::pollpri_event(int)’: ../misc.cpp:149:42: warning: statement has no effect [-Wunused-value] ../misc.cpp:150:44: error: ‘req’ was not declared in this scope ../misc.cpp:151:21: error: ‘revents’ was not declared in this scope ../misc.cpp:152:42: warning: statement has no effect [-Wunused-value] ../misc.cpp: In function ‘void init(v8::Handle<v8::Object>)’: ../misc.cpp:160:33: warning: statement has no effect [-Wunused-value] make: *** [Release/obj.target/misc/misc.o] Error 1 make: Leaving directory /root/node_modules/bonescript/build’
gyp ERR! build error
gyp ERR! stack Error: make failed with exit code: 2
gyp ERR! stack at ChildProcess.onExit (/usr/local/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:267:23)
gyp ERR! stack at ChildProcess.EventEmitter.emit (events.js:98:17)
gyp ERR! stack at Process.ChildProcess._handle.onexit (child_process.js:789:12)
gyp ERR! System Linux 3.8.13-bone20
gyp ERR! command “node” “/usr/local/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “build”
gyp ERR! cwd /root/node_modules/bonescript
gyp ERR! node -v v0.10.19
gyp ERR! node-gyp -v v0.10.10
gyp ERR! not ok
npm ERR! weird error 1
npm ERR! not ok code 0
