I am trying to install the Stockfish Chess engine on my BBB under Angstrom.
It is not listed under OPKG
The standard pre-compiled Linux versions do not seem to work, so I am trying to compile myself.
I used the latest image and did a OPKG update
I used git to successfully copy across Stockfish using:
git clone git://github.com/mcostalba/Stockfish.git
Then tried various options on Make:
make profile-build ARCH=general-32 seemed to get the furthest but failed with:
/usr/lib/gcc/arm-angstrom-linux-gnueabi/4.7.3/…/…/…/…/arm-angstrom-linux-gnueabi/bin/ld: cannot find -lgcov
Not really a Linux user, so not sure what the problem is, could be a dependancy, but what?
If this doesn’t work thinking of trying Ubuntu or Debian as Stockfish instalation supported by apt-get install on other platforms e.g. RPi so I assume it might be on the BBB.
more detailed log attached.
Any suggestions gratefully recieved.
Max
To compile stockfish.docx (14.4 KB)
