installing just the command line...
Hello all,
     I'm only interested in the command line side of Linux. BB will
only be used for music and I decided to use XMMS2 for my music
playback. I'll be able to access the player through the web, SSH, or
if need be I can hook up a monitor for test purposes only.
    I'm trying to make the linux install as SMALL as possible. Any
suggestions on how I should approach this idea and what distro should
I use?
-Thank You,
     Rich
Go to http://amethyst.openembedded.net/~koen/narcissus/ and only select the components you need.
regards,
Koen
Amazing! Thank you for your quick response. This will come in
handy :slight_smile:
-Thank you,
     Rich
