I run ArchLinux ARM on my BBB from the on board eMMC. I create a microSD image on another ARM Linux system (a PogoPlug) and install that image on the eMMC using a series of three scripts.
Script 1 - partitions/formats the microSD card
Script 2 - installs the ArchLinux files on the microSD card
Script 3 - I execute on the BBB once I’ve booted the BBB with the microSD I just prepared.
There are some custom/unique items in my scripts (e.g., to run Script 2 it assume the Script 3 file called bbb-make-emmc-arch.sh is actually on your Linux system so it can be copied to the microSD card and executed as the last step in my installation process). Even if you don’t use ArchLinux ARM, there is still helpful information for folks who may want to create their own eMMC initialization scripts. Below are my three scripts … enjoy.
Script 1
bbb-fdisk-sd.sh
This script partitions SD media for use as a boot device for a BeagleBone
or BeagleBone black. The first partition (boot) is sized at 16MB. If you
want a larger partition, change the code below (look for +16M). This script
assumes the device you want to partition is located at /dev/sd?. Make sure
you verify the correct device name before proceeding.
DEVICELIST=ls /dev/sd? 2> /dev/null | sed s:/dev/::
if [ -z “${DEVICELIST}” ]; then
echo “ERROR: No /dev/sd? devices”
exit
fi
clear
echo Device Choices: $DEVICELIST
echo
while true
do
read -p "Enter device name: " DEVICECHOICE
if echo “$DEVICECHOICE” | grep -q “$DEVICELIST”
then
break
else
echo “ERROR: You entered an invalid device name.”
fi
done
echo
while true
do
read -p "Are you sure you want to use /dev/$DEVICECHOICE (answer yes or no)? " ANSWER
case $ANSWER in
yes ) break;;
no ) exit;;
- ) echo “ERROR: Please answer yes or no.”;;
esac
done
fdisk /dev/$DEVICECHOICE << EOF
o
p
n
p
1
+16M
n
p
2
a
1
t
1
e
p
w
EOF
Script 2
bbb-make-sd-arch.sh
This script is used to create a new (clean) install of ArchLinux for the BeagleBone or
BeagleBoneBlack on a microSD card. Verify your media devices before you proceed. This
script assumes your media device is /dev/sd?. Ensure you have partitioned (fdisk) your
media before proceeding. You will need two partitions. The first partition does not need
to be large, but needs to be set to bootable and must be type ‘e’ which is FAT 16.
The second partition is a normal Linux partition, probably ext4. If you can’t mkfs.vfat,
download the dosfstools (pacman -Sy dosfstools).
clear
exit
fi
echo
while true
do
then
break
else
fi
done
echo
while true
do
case $ANSWER in
yes) break;;
no) exit;;
*) echo “ERROR: Please answer yes or no.”;;
esac
done
BOOTLOADER=BeagleBone-bootloader.tar.gz
ARCHLINUX=ArchLinuxARM-am33x-latest.tar.gz
WORKINGDIR=.
BOOTDEV=/dev/$DEVICECHOICE’1’
BOOTTMP=$WORKINGDIR/boot
ROOTDEV=/dev/$DEVICECHOICE’2’
ROOTTMP=$WORKINGDIR/root
BOOTIMAGE=$ROOTTMP/boot/zImage
BBBSCRIPT=/home/public/bbb-make-emmc-arch.sh
mkfs.vfat -F 16 -n “bootloader” $BOOTDEV
sleep 1
mkfs.ext4 -L “rootfs” $ROOTDEV
sleep 1
mkdir $BOOTTMP
mkdir $ROOTTMP
mount $BOOTDEV $BOOTTMP
mount $ROOTDEV $ROOTTMP
wget http://archlinuxarm.org/os/omap/$BOOTLOADER -O $WORKINGDIR/$BOOTLOADER
sleep 1
wget http://archlinuxarm.org/os/$ARCHLINUX -O $WORKINGDIR/$ARCHLINUX
sleep 1
if which pv &> /dev/null
then
pv $WORKINGDIR/$BOOTLOADER | tar xzf - -C $BOOTTMP
pv $WORKINGDIR/$ARCHLINUX | tar xzf - -C $ROOTTMP
else
tar xvf $WORKINGDIR/$BOOTLOADER -C $BOOTTMP
tar xvf $WORKINGDIR/$ARCHLINUX -C $ROOTTMP
fi
echo “Copying Boot Image”
cp $BOOTIMAGE $BOOTTMP
echo “Copying” $BBBSCRIPT “script to /”
cp $BBBSCRIPT /
echo “Synching”
sync
umount $BOOTTMP
umount $ROOTTMP
rmdir $BOOTTMP
rmdir $ROOTTMP
clear
echo “Upload Complete”
echo
while true
do
read -p "Delete downloaded files (answer yes or no)? " ANSWER
case $ANSWER in
yes )
rm $WORKINGDIR/$BOOTLOADER
rm $WORKINGDIR/$ARCHLINUX
exit
no ) exit;;
esac
done
Script 3
This script is used to create a new (clean) install of ArchLinux ARM to the BeagleBone Black’s
onboard eMMC storage. This script assumes you have booted the BeagleBone Black using a microSD
card with the appropriate ArchLinux ARM files and now want to install ArchLinux in the onboard
eMMC memory.
WORKINGDIR=/tmp
BOOTDEV=/dev/mmcblk1p1
ROOTDEV=/dev/mmcblk1p2
clear
while true
do
echo “You need the mkfs.vfat format and wget commands.”
echo “Use pacman -Sy wget AND pacman -Sy dosfstools (for vfat format).”
echo
read -p "Are these two commands installed (answer yes or no)? " ANSWER
case $ANSWER in
yes) break;;
no) exit;;
esac
done
sleep 1
sleep 1
mkdir $BOOTTMP
mkdir $ROOTTMP
sleep 1
sleep 1
then
else
fi
echo “Synching”
sync
umount $BOOTTMP
umount $ROOTTMP
rmdir $BOOTTMP
rmdir $ROOTTMP
clear
while true
do
case $ANSWER in
yes)
exit
no) exit;;
esac
done
