instructions for building angstrom for BB
it's been a few weeks since i've messed with my BB so, getting back
to it, i'm following my own instructions that i wiki'ed here:
http://www.crashcourse.ca/wiki/index.php/Angstrom
i'm about to update all my downloads and see if those build
instructions still work. anyone else is welcome to try them as well
and see what breaks. :slight_smile:
rday
Please don't duplicate information, there are already way to many out-of-date copies out there :frowning:
regards,
Koen
i'm aware of that, but there was no single source i found that was
complete and correct. and you're right -- there *are* way too many
HOWTOs out there, and if you take them all, and combine them, *then*
you will probably get a working set of instructions. but as of the
time i wrote that writeup, there was nothing out there that *just*
*worked*. what i wanted -- for my own benefit -- was a set of
instructions that worked. every time.
rday
p.s. as i type this, my "bitbake base-image" is cranking along, but
here's an early snippet of the output:
NOTE: Parsing finished. 0 cached, 6374 parsed, 283 skipped, 0 masked.
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version git of u-boot not available (for item u-boot)
NOTE: Preparing runqueue
NOTE: Executing runqueue
  so where do i report that u-boot diagnostic? the OE mailing list?
the angstrom list? the beagleboard list? that's why this is
sometimes confusing.
Can you state clearly WHICH instructions are the recognized official
up-to-date version that everyone should be using? -Dan
I believe Koen's referring to:
http://www.angstrom-distribution.org/building-ångström
Op 23 jul 2009 om 22:42 heeft Robert Nelson <robertcnelson@gmail.com>
het volgende geschreven:\
indeed
and, in fact, i link to that page from my wiki. all i do is add
some preliminary info that needs to be done under fedora for those
instructions to work.
  and i'm still not sure where i would report this diagnostic from my
current build of base-image:
if i'm reading things correctly, the beagleboard wants u-boot-1.1.4,
which *seems* available. so what am i doing wrong?
rday
