I am currently working on a integration of a TLV320AIC31 codec with
Beagleboard through the McBSP interface. The pinmux interconnections
are mapped as following:
BCLK -> McBSP3_CLKX
WCLK -> McBSP3_FSX
DOUT -> McBSP3_DR
DIN <- McBSP3_DX
So this part should be solved. I've also modified the sound/soc/omap/
omap3beagle.c for correct ASoC glueing for the TLV320AIC31 codec
(which is in the kernel already). Although I am not sure about what
should be done in the arch/arm/mach-omap2/board-omap3beagle.c file, it
contains the following structs for the audio data handling (which is
orginially written for the integrated TWL4030/TPS69590 codec):
static struct twl4030_codec_audio_data beagle_audio_data;
static struct twl4030_codec_data beagle_codec_data = {
.audio_mclk = 26000000,
.audio = &beagle_audio_data,
I have searched through the architecture files that uses the TLV codec
by default (board-n8x0.c etc) and I have difficulties to make the
translation for my TLV codec in the omap3beagle.c file. I see that the
N810 uses a aic3x_pdata with .gpio_reset and setup_data and I'm not
sure how to make this on the beagle (if needed?). If someone could
come with some clarifying information on how it should be done I would
be very grateful.
Thanks in advance!
Regards
Juha
