I got an HTU21D temperature and humidity breakout board from Sparkfun (https://www.sparkfun.com/products/12064). Since I’m a novice at electronics I’m unsure if I’ve made an error in connecting the device or there is some device driver issue. I connected the breakout to my beaglebone black as follows:
- : Pin 3 (VDD)
- : Pin 1 (GND)
CL : Pin 19
The datasheet says 3.8V maximum and since the VDD is 3.3V, I thought no logic level converter would be necessary. Running i2cdetect doesn’t show anything connected. The output is as follows:
i2cdetect -r -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – -- – -- – -- – -- – -- – -- –
10: – -- – -- – -- – -- – -- – -- – -- – --
20: – -- – -- – -- – -- – -- – -- – -- – --
30: – -- – -- – -- – -- – -- – -- – -- – --
40: – -- – -- – -- – -- – -- – -- – -- – --
50: – -- – -- UU UU UU UU – -- – -- – -- – --
60: – -- – -- – -- – -- – -- – -- – -- – --
70: – -- – -- – -- – --
I tried to initialize the driver by running:
echo htu21 0x40 > /sys/class/i2c-adapter/i2c-1/new_device
This is what I see in dmesg:
[215690.914098] i2c i2c-1: new_device: Instantiated device htu21 at 0x40
But there are no directories created under ‘/sys/bus/i2c/drivers’ corresponding to this driver.
Rushi
