Internet beagleboneblack
Hi everyone,
I’m a french newbie on beagleboneblack, and I feel really hard to use it after the beaglebone original.
My first unsolved problem was setting up gpio in kernel (because the /sys/class/gpio files are useless if gpio are not set in mode7 and correct direction). So if you can tell me what I have to send by echo command in /pinmux-pins please tell me :’ ).
But that is not the topic, I must connect my board to internet to update my opkg and install .ik without dirty downloads.
I’m on fedora 19
I connect to beagle by ssh 192.169.7.2
An ifconfig on host gives me :
em1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.121 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::224:e8ff:fee3:2d3 prefixlen 64 scopeid 0x20
ether 00:24:e8:e3:02:d3 txqueuelen 1000 (Ethernet)
RX packets 44200 bytes 23712418 (22.6 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 28736 bytes 8067058 (7.6 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 22 memory 0xf6ae0000-f6b00000
enp0s29f7u2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.7.1 netmask 255.255.255.252 broadcast 192.168.7.3
inet6 fe80::c6ed:baff:fe7c:28d8 prefixlen 64 scopeid 0x20
ether c4:ed:ba:7c:28:d8 txqueuelen 1000 (Ethernet)
RX packets 2152 bytes 236403 (230.8 KiB)
TX packets 3104 bytes 448390 (437.8 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 0 (Boucle locale)
RX packets 4 bytes 236 (236.0 B)
TX packets 4 bytes 236 (236.0 B)
An ifconfig on beagle gives:
eth0 Link encap:Ethernet HWaddr C4:ED:BA:7C:28:D6
UP BROADCAST MULTICAST MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:56
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:18 errors:0 dropped:0 overruns:0 frame:0
TX packets:18 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1392 (1.3 KiB) TX bytes:1392 (1.3 KiB)
usb0 Link encap:Ethernet HWaddr 76:61:56:59:4A:E6
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
RX packets:3123 errors:0 dropped:0 overruns:0 frame:0
TX packets:2162 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:269754 (263.4 KiB) TX bytes:362727 (354.2 KiB)
I’ve ever tryed lots of things founded on the web (like using .sh gived to setup ip following, etc …).
Please help me.
