Hi all,
I needed to code an application in C which receives and processes GPIO interrupts on BB xM.
I cannot use a polling scheme. I found how to configure and use GPIO’s and enable interrupts to the Processor
But I cannot find a sample code that shows something.
In linux , I found that this can be done using functions provided by ‘linux/interrupt.h’.However I could not find this header in
/usr/include/
Could someone help me with a basic interrupt service routine on BeagleBoard ?
I would like to directly configure the GPIO’s (can do that) than using the export method
Regards
Jude
Hi all,
/usr/include/
Hi Jude,
You are confusing user space code with kernel space code. You will find interrupt.h in /include/linux when looking at the Linux kernel code. You will want to create a GPIO device driver which will setup code to capture GPIO interrupts. Not sure what you want to do once the interrupt is generated.
John
