Hi Dennis,
I tried on the groups site to edit this post and change what I wrote.
While the master copy appears to be a Google Groups entry, it seems to
be propagated outward since gmane is able to copy it and provide NNTP
access (which is how I'm reading -- but about a year ago submitted replies
via gmane were getting rejects from the main group, so I've had to email
replies to Google...).
NNTP spec does offer a CANCEL command to delete posts... BUT most
servers have disabled that (too easy to spoof a user and delete posts one
objects to, perhaps).
Since the messages are on distributed servers, they are essentially
"fire and forget" -- there is nothing one can do once they've hit send...
It's a good point you make there. However then the SizeOf function might well return something different in size to make everything fit. I've also heard of systems re-arranging the members of a record to suit. In pascal to make that happen you defined it as packed.
My concern was that the C code might be packing things differently from
FreePascal, which could mean some of the arguments will not be where the
kernel expects to find them.
OTOH: I believe ARM Cortex architecture is defined to use byte
alignment (even if word/longword alignment is how the memory bus operates),
so both C and Pascal should be generating packed structures.
Because this example program uses the high speed gpio the fault happens much sooner on the Pi without the sudo.
pi@raspberrypi:~/projects/lazarus/TC $ ./TC
An unhandled exception occurred at $00084EE4:
ERPiOpenFile: Cannot not open file </dev/mem> for memory mapping.
$00084EE4 TFASTSYSTEMCORE__CREATE, line 451 of /home/pi/projects/lazarus/pxl/Source/PXL.Boards.RPi.pas
$00010410 main, line 95 of TC.lpr
That may be devolving to the similar timing problem as earlier -- if it
is doing memory mapping to get to GPIO rather than using the sysfs access,
it may take time to get memory privileges set up.
https://man7.org/linux/man-pages/man4/mem.4.html
Hmmm, it appears that /dev/mem is a udev victim. Freshly booted a BBB gave
crw-r----- 1 root root 1, 1 Dec 31 1999 mem
but repeating the command a few seconds later shows
crw-r----- 1 root kmem 1, 1 May 25 23:45 /dev/mem
(note that the first is using the system default date, while the second is
after the system synched clocks).
Making the R-Pi user a member of group kmem might improve things; the
Beagle already has kmem for user
debian@beaglebone:~$ groups debian
debian : debian adm kmem dialout cdrom floppy audio dip video plugdev users
systemd-journal input bluetooth netdev i2c gpio admin spi iio docker tisdk
weston-launch xenomai cloud9ide pwm eqep remoteproc
