Curious what the difference is with the IoT variant:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Jessie_Snapshot_iot
thanks,
drew
thanks,
drew
It's pretty much the lxqt image with no lxqt/xorg packages
It's sitting around 1.6GB installed on first bootup..
It’s pretty much the lxqt image with no lxqt/xorg packages
It’s sitting around 1.6GB installed on first bootup…
Also technically the first image to have Nodejs 0.10.x, and 0.12.x running side by side too ?
Nah, i moved things to utilize
https://github.com/nodesource/distributions
Instead, less for me to watch for, and 'nodesource' builds all
versions, for all distro's.
So nodejs v0.12.x is installed by default, but you can switch/upgrade to:
node_0.12
iojs_2.x
iojs_3.x
node_4.x
node_5.x
Just by tweaking: /etc/apt/sources.list
debian@beaglebone:~$ cat /etc/apt/sources.list | grep node
deb https://deb.nodesource.com/node_0.12 jessie main
#deb-src https://deb.nodesource.com/node_0.12 jessie main
thanks!
