please how can i forward ip address of a sim 7600e to a beaglebone wifi. so as to use it has hotspot?
Let me try to explain what you will have to do:
- Connect the module to the BBBW.
- It has USB drivers so it should be straight forward to enable it as a network node.
- A small cape could be designed to do this, RPi hats do exist
- https://www.elementzonline.com/blog/Accessing-internet-with-SIM7600-4G-Modem-using-MBIM-interface-in-Pocketbeagle-Beaglebone
- Set up a WiFi gateway (Wifi access point credentials + DHCP server for this port)
- Bridge the gateway with the network port offered by the SIM7600e driver
- Set up a firewall to avoid malicious access from both WiFi and Cellular
It is a bit more complex than forwarding the IP address, but it is a well documented setup.
But you are lucky: the standard Debian OS prepares the WiFi as an access point, you just have to arrange the SIM7600e integration and the bridge & Firewall
Gwen
Thanks for your reply, I have been able to get internet connectivity from the modem using MBIM and also I have created a WiFi gateway + DHCP server using COMMANCTL but where I have problem is the bridging the gateway with the network port offered by the 4g modem. Thanks again
Here is some explication/tutorial on bridging the two networks in your BBW
https://wiki.debian.org/BridgeNetworkConnections
Gwen
Thanks Gwen, Do you have any idea how I can manage the WiFi network on beagle bone wireless without using CONNMANCTL
Kind regards,
Josiah
No, I haven’t tried to remove connmanctl
I have no problem with the application, as it does exactly what I want it to do.
There is quite some configuration behind the curtains, dive deeper into the configuration files and you might find the settings you want to alter.
Gwen
Thanks Gwen.
I really appreciate your effort.
I will get back to you
Again… a big thanks
Hi Josiah!
Hello Tarmo
Hi Tarmo,
I have tried to use ConnMan to tether the modem dialup connection but it requires ofono which is not well documented, I have also tried to tweak connman settings and I am not getting results. I guess connman tether is restricted to wlan and eth0 network not cellular connection.
Hi Gwen
I was able to use WhatsApp after I did IP forwarding but I can’t get my browser or other application to connect to the internet, do you have any idea why?
Josiah
idea why?
What error message do you get? Maybe try running `wget --spider
http://www.beagleboard.org` on your client machine and paste what
happens. If all is working, you should see this:
$ wget --spider http://www.beagleboard.org
Spider mode enabled. Check if remote file exists.
--2019-12-20 09:46:21-- http://www.beagleboard.org/
Resolving www.beagleboard.org... 44.226.162.25
Connecting to www.beagleboard.org|44.226.162.25|:80... connected.
HTTP request sent, awaiting response... 303 See Other
--2019-12-20 09:46:22-- https://beagleboard.org/
Resolving beagleboard.org... 44.226.162.25
Connecting to beagleboard.org|44.226.162.25|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 27837 (27K) [text/html]
Remote file exists and could contain further links,
but recursion is disabled -- not retrieving.
Have you set your client's default gateway correctly? (If you're using
DHCP, check the DHCP settings on your DHCP server… possibly running on
the BeagleBoard.)
Have you set your client's DNS servers correctly? (If you're using
the BeagleBoard.)
Can the DNS servers and default gateway be reached by the client? Most
will respond to ICMP echo request, so try a `ping` (or `ping6` if they
are IPv6).
Hi everyone… please i have tried the method for the IP forwarding from my sim module to the BB to be able to be us as Hotspot(WiFi) but going through the fore given process, i realize that only WhatsApp Instant Messaging App is going… Other browser(Google chrome, Mozilla) are not going. i am thinking maybe its because of the protocol used by WhatsApp thats why its going through. Please i need assistance on this. How can i make it work swiftly and allow it to be compatible with any device and any APP.
Any one who have done this before should be of help
Hi everyone... please i have tried the method for the IP forwarding from my
What steps did you follow? You've quoted my email in it's entirety then
top-posted yet more begging "please make it work". Computers don't
respond to religion.
You're dealing with the Technology Genie here: he'll grant you unlimited
wishes, *BUT* expects you get to understand him in return. If you don't
want to do that, pay someone who already does understand him.
is going... Other browser(Google chrome, Mozilla) are not going.
What about the `wget` command I suggested? What was its output? Or are
you just going to ignore our questions and hope we can magically solve
it for you?
I lost my crystal ball in the 2011 Brisbane floods.
i am
going through.
… which is why I suggested doing some lower-level checks.
Think of the OSI model, check…
- physical layer (e.g. cable connections, radio settings)
- data link layer (e.g. VLANs, LACP, SSIDs, crypto settings)
- network layer (e.g. IP addresses, routes)
- application layer (e.g. DNS)
… IN THAT ORDER.
You're starting from the presentation layer (web browser, WhatsApp) and
working down. You can't debug a network that way!
Then answer our questions. We cannot read minds.
Not done it with the exact hardware combination you're talking of, but
I've done it many times before on various systems including:
- dial-up modems on a standard x86 machines running Linux
- ADSL(v2) modems with PPPoE and standard x86 machines running Linux
- 3G/LTE with various systems (including MIPS and ARM) on Linux
Once you get the "router" (the thing the modem/module plugs into) onto
the Internet, making it accessible to a network behind it is not rocket
science, and actually hasn't changed much since Linux kernel 2.4 (5.x
still uses `iptables`).
Thanks stuartl.
I have fix and it has worked fine
I know computer don’t respond to religion and I have make it work.
Once agin thanks
