Hallo,
I’ve prepared new set of IPipe patches for 3.13 series Robert C Nelson’s Kernel build system.
The patches are available over git repo: https://github.com/t-szczyrba/bbb-xenomai-patches
regards,
T.
Hallo,
regards,
T.
Very cool.. I'm a little surprised about v3.13.x being the base. Thought
Xenomai & RT was usually patched against even releases? My plan with
v3.13.x was just a quick release, and switch to v3.14.x asap and then just
keep updating v3.12.x/v3.14.x while dropping v3.13.x. Maybe i better not
do that too quickly..
Very cool… I’m a little surprised about v3.13.x being the base. Thought Xenomai & RT was usually patched against even releases? My plan with v3.13.x was just a quick release, and switch to v3.14.x asap and then just keep updating v3.12.x/v3.14.x while dropping v3.13.x. Maybe i better not do that too quickly…
Thanks, but better do it as usual, because I am really second-class developer: not perfect in kernel development (I spend much more time reading docs & sources than coding & trying), also I drive my company and do the ipipe work in very little spare time .
As far as I noticed:
I check it following way: after booting I run quick & simple random FS read (I use ext4): ls -lR / | grep ???
when during the read anything is flawed I see some signatures with permissions printed as ???
There are also some modifications which could be applied to Your 3.13 tree from Beagle’s 3.8: JTAG (debugss) clock enable etc…
regards,
T.
