Hi Linux Crypto friends,
We are designing a new hardware crypto module with DES,SHA ,MD5 and
AES to off load processor.The task is to use the hardware acceleration
instead of using default software implementations in kernel.
Splitting my task into two parts
Part-1:Hardware crypto acceleration for userspace applications like
openssl
openssl
In this part, I would like to integrate my low level crypto driver
hardware acceleration code in /dev/crypto module and would like to
load it as openssl engine.
1)Are there any draw backs in my approach?
2)Are there any other better methods that can be implemented here
instead of the above approach?
3)My main aim is that all the user applications should use my hardware
acceleration?Will the above /dev/crypto approach solve my purpose?
Part-2:Hardware crypto acceleration for Ipsec
I am not clear how to implement this part?
1)In this part,I understood from blogs that the native IPsec stack in
kernel uses Kernel Crypto API.
Am I right?
2)If I am right,Is it recommendable to hack Kernel Crypto API to use
our hardware acceleration code?
3)I heard about openswan,strongswan,racoon and isakmpd IPsec
stack.would replace the native IPsec stack in kernel? Am i right?
If I am wrong, I hope the above (openswan,strongswan,racoon and
isakmpd IPsec stack) would use the native IPSec stack?
If I am right,Can I hack any of the above IPsec stacks to implement my
4)What is the best way to off load processor and make IPsec to use my
Happy Crypting
Tilak
