Is it possible to issue start command from OMAP to restore the I2C lines?
Hi All,
I am using OMAP34x processor with Linux kernel 2.6.22.18 for
development. The setup I am using has OMAP as master and a few slave
devices connected to it via the I2C bus.
Due to some reason, the SDA line is held low and I2C becomes unstable.
In this scenario is it possible for OMAP to issue a start command to
restore the I2C lines (as master)?
Please advice.
Ruchi Sirauthiya
Hi Ruchi,
In case one of your I2C slaves becomes unstable and decides to hold low the
SDA line for ever, the OMAP being I2C-master can't do anything against it.
The I2C-bus is an open-collector bus, and in case one slave device decides
to hold down one line for ever (due to whatever reason), you are basically
just stuck :slight_smile:
You therefore need to figure out why the device goes haywire and fix this
situation up front. Alternatively a reset of the device (if you have such
one connected to an OMAP GPIO ball) should be able to fix the situation as
well...
In case it's the OMAP itself, which decides to hold down SDA forever (due to
a yet unknown bug), you can of cause reset the I2C IP-core in OMAP and start
over, but as I read your request I assume the problem is caused by one of
the attached slaves and not the OMAP - Correct?...
Good luck
  Søren
Thanks Søren,
As you told, if a slave device is holding the line we cannot do much
from the OMAP side, we should reset the slave to recover from I2C time
out. In most cases resetting the slave device will help in I2C bus
recovery. In some very rare cases, it just displays the message "I2C
time out waiting for bus ready" and never recovers. In this case even
after resetting the slave, SDA line does not come up.
In this specific case what could be the issue? Will resetting I2C bus
from the OMAP side help? How do I initiate a I2C IP-core reset in OMAP
and start over?
Ruchi
Hi Ruchi,
In this case even after resetting the slave, SDA line does not come up.
In case it isn't any of the slaves it must be the OMAP howing down the line
- I agree:-)
That being said I have not seen any HW-related problems with the OMAP I2C
module in the newer OMAPs. The OMAP15xx chips had a few strange bugs, but
this is fixed a long time ago. Checking the errata
(http://focus.ti.com/lit/er/sprz278d/sprz278d.pdf) advisory 3.1.1.15 might
though be interesting. I don't know if this is incorporated in the Linux I2C
code?
Will resetting I2C bus from the OMAP side help? How do I initiate a I2C
IP-core reset in OMAP and start over?
An "OMAP I2C IP-block reset" will restart the I2C block (and remove the
hanging), but I unfortunately don't know how to do this (if it's possible to
be done) in a controlled manner from Linux, since I have never had the need
to do this...
You can find information about the I2C IP block details in the OMAP3530 TRM
(spruf98d.pdf) chapter 18...
Good luck
  Søren
