I’m looking for a solid model of the board to fit into my drone project. In .stp format would be fine. Need for clearances, mounting hole locations and possibly an enclosure.
Hi Mart,
I recently put together a CAD model of the BBB using EagleCAD and Fusion 360. You can find it here: https://grabcad.com/library/beaglebone-blue-1
It should be pretty accurate as it’s based off the BBB Eagle file in the GitHub repo, however it’s possible that some things might be out by a little bit. I would still double check any critical measurements!
Hope it helps!
Thanks, so nice of you to share your work! I was able to import it into openshape as well.
Sweet thanks!!
