Issue Applying BBX15 Patch to X15 u-boot
Hope everyone in the Southeast on this site (and in general) is starting to put the pieces back together post- storm Harvey.
Last-night and today I tried applying the latest patches for the BB-X15 to the 2017.01 branch of u-boot per the instructions on eewiki, https://eewiki.net/display/linuxonarm/BeagleBoard-X15, when I got some errors when applying the 0001``-beagle_x15-uEnv.txt-bootz-n-fixes.patch patch.
I followed all the steps but when I got to the apply patch step for the x15 patch, I got the following errors:
Some Hunks failed while most succeeded (see below). I didn’t really try to go any further, since I haven’t seen this before.
Thanks and FYI!!
Jeff
~/build57xxUboot/retrievedFromEEWikiByDate/31_Aug_2017/u-boot$ patch -p1 < 0001-beagle_x15-uEnv.txt-bootz-n-fixes.patch
patching file Makefile
patching file arch/arm/dts/Makefile
Hunk #1 FAILED at 143.
1 out of 1 hunk FAILED – saving rejects to file arch/arm/dts/Makefile.rej
patching file arch/arm/dts/am571x-sndrblock-common.dtsi
patching file arch/arm/dts/am571x-sndrblock.dts
The next patch would create the file arch/arm/dts/am57xx-beagle-x15-revc.dts,
which already exists! Assume -R? [n]
Apply anyway? [n]
Skipping patch.
1 out of 1 hunk ignored
patching file board/ti/am57xx/board.c
Hunk #1 FAILED at 37.
Hunk #2 succeeded at 90 (offset 2 lines).
Hunk #3 succeeded at 485 (offset 2 lines).
Hunk #4 succeeded at 501 with fuzz 2 (offset 2 lines).
Hunk #5 succeeded at 527 (offset 4 lines).
Hunk #6 succeeded at 599 (offset 4 lines).
Hunk #7 FAILED at 737.
Hunk #8 FAILED at 1147.
Hunk #9 succeeded at 1172 (offset 8 lines).
3 out of 9 hunks FAILED – saving rejects to file board/ti/am57xx/board.c.rej
patching file configs/am57xx_evm_defconfig
Hunk #2 FAILED at 61.
1 out of 3 hunks FAILED – saving rejects to file configs/am57xx_evm_defconfig.rej
patching file include/configs/ti_armv7_common.h
patching file include/configs/ti_omap5_common.h
Hunk #2 FAILED at 101.
Hunk #3 FAILED at 117.
2 out of 3 hunks FAILED – saving rejects to file include/configs/ti_omap5_common.h.rej
patching file include/environment/ti/mmc.h
patching file scripts/Kbuild.include
patching file scripts/Makefile.extrawarn
Yeah, ti merged x15_revc support into their u-boot tree.. Haven't had
much free time at work to fix it yet..
I'll update those instructions to checkout this git-sha as a base:
590c7d7fe15d06a4d708403d3234bcd01cd039e1
Ok thanks a lot!
Is the Rev. B board essentially the 572xEVM, whereas the Rev. C board is the BeagleBoard-X15?
Where’s the best place to see what all changed from board revision B to C?
https://github.com/beagleboard/beagleboard-x15/blob/master/BeagleBoard_X15_RevC2_BOM.xlsx ?
Thanks!!
Actually the 572xEVM got forked around Rev A2..
Rev B's pass FCC...
Rev C is just a Rev B with SR2.0 silicon. (plus a few pull-up resistor
changes, for SR2.0 silicon)
