Issue loading .bin code to PRU - prussdrv_open() open failed - 4.9.45-ti-r57
I’ve been playing with this BBBW for several months, and I feel like I’ve come quite far from newbie status, but I’m feeling a lot like a newbie again right now after having so much trouble programming the PRU’s : 0 please help!
I’ve been following this tutorial: http://credentiality2.blogspot.com/2015/09/beaglebone-pru-gpio-example.html - mostly because it makes a lot of intuitive sense to me.
I’ve modified the device overlay code shown in the tutorial to use different GPIOs (with correct configuration settings for my gpios) and I’ve written a basic assembly code to toggle my gpios (simply so I know it works - before I move on to harder stuff). I’m able to compile the device overlay into a dtbo and I can load it into /sys/devices/platform/bone_capemgr/slots no problem. I’ve even been able to download unpack and make the am335x_pru_package so that I can use pasm to compile my assembly into .bin but now the issue that I can find no helpful info on, is during the process of running the c code in the mentioned tutorial to load the .bin into the PRU.
The pru loader is a simple .c file called pru_loader.c which I haven’t modified at all from the code listed in the tutorial, but when I use it to load my compiled assembly code (pru_gpio_test.bin) with this command:
“./pru_loader pru_gpio_test.bin”
I get this error:
“prussdrv_open() failed”
Can anyone help me? I can you any information you need that I haven’t listed here. I’m running out of places to look online : 0
Thank you for reading!
evangrcarter@gmail.com
