Hi;
Using the old kernel cape-manager I was able to dcan1 working with a few tries.
Since updating to bone-debian-9.5-iot-armhf-2018-10-07-4gb.img I have not been successful using the new u-boot device tree system.
I have tried to follow several other threads without success.
My old code relied on the test that the dcan1 rx and tx lines are both set to Mode-2 in the pin-mux
No matter how I mix-up using the old and new device tree code I cannot get a 0x2 in the last position of
debian@beaglebone:~$ sudo devmem2 0x44E10980 w /dev/mem opened. Memory mapped at address 0xb6f8c000. Value at address 0x1155598720 (0xb6f8c980): 0x18 <-- should have 2 in lower three bits debian@beaglebone:~$ sudo devmem2 0x44E10984 w /dev/mem opened. Memory mapped at address 0xb6fa5000. Value at address 0x1155598724 (0xb6fa5984): 0x50 <-- should have 2 in lower three bits
In trying to stick to the dtb_rebuilder method I currently have included
#include "am335x-bone-pinmux-can1.dtsi"
in the top of src/arm/am335x-boneblack.dts and rebuild/install
When I boot with this modified device tree I can see lines in pinmux-pins
debian@beaglebone:~/dtb-rebuilder/src/arm$ cat /sys/kernel/debug/pinctrl/44e10800.pinmux/pinmux-pins | grep dcan pin 96 (PIN96): 481d0000.can (GPIO UNCLAIMED) function pinmux_dcan1_pins group pinmux_dcan1_pins pin 97 (PIN97): 481d0000.can (GPIO UNCLAIMED) function pinmux_dcan1_pins group pinmux_dcan1_pins
and am able to setup linux can0
debian@beaglebone:~$ sudo modprobe can
debian@beaglebone:~$ sudo modprobe can-dev
debian@beaglebone:~$ sudo modprobe can-raw
debian@beaglebone:~$ sudo ip link set can0 type can bitrate 250000
debian@beaglebone:~$ sudo ip link set can0 up
debian@beaglebone:~$ ifconfig can0
can0: flags=193<UP,RUNNING,NOARP> mtu 16
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 10 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 36
But I am still unable to send or receive any messages using candump or cansend.
My big concern is that the pin-muxing is not being set correctly when I check the control register in the am533 chip.
Am I wrong that the dump of the pin-muxing register should end in 2?
Thanks in advance, I appreciate any help.
Miller
