Issues while eMMC partitioned using sfdisk
I am writing firmware(MLO,u-boot.img, uImage(ver 3.12), dtb, rootfs.tar.gz) programming script for
am335x based custom board which is based on Beaglebone black.
Rootfile system is to be put onto the eMMC.
Firmware programming script runs as the one of the init script from
the nfsroot folder when board boots for the first time at programming station.
Basically script
  1. Partitions the eMMC and
  2. writes MLO, u-boot.img, uImage, dtb in the raw area of the first partition and
  3. Then formats the other partitions as ext4 and
  4. mounts ext4 partitions and extacts the rootfs.tar.gz.
Now there are two issues with the script and one with backup kernel memory area.
Script issues
  1. I am not able create more than 7 partition(including logical partitions)
    though sfdisk creates the partitions, device files related to partition is not available in /dev directory
Here is sfdisk command i used
#Partition emmc
sfdisk -D -H 255 -S 63 -C 467 /dev/mmcblk0 -uM << EOF
,32,C,*
,200,L
,200,L
,E
,100,L
,60,L
,200,L
;1269,L
EOF
When i list the partitions fdisk/sfdisk reports 8 partitions but i don’t see partition files related to 8th partition.
Here is fdisk output for the same,
fdisk -l /dev/mmcblk0
Disk /dev/mmcblk0: 3841 MB, 3841982464 bytes
255 heads, 63 sectors/track, 467 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Device Boot Start End Blocks Id System
/dev/mmcblk0p1 * 1 5 40131 c Win95 FAT32 (LBA)
/dev/mmcblk0p2 6 31 208845 83 Linux
/dev/mmcblk0p3 32 57 208845 83 Linux
/dev/mmcblk0p4 58 467 3293325 5 Extended
/dev/mmcblk0p5 58 70 104391 83 Linux
/dev/mmcblk0p6 71 78 64228+ 83 Linux
/dev/mmcblk0p7 79 104 208813+ 83 Linux
/dev/mmcblk0p8 105 266 1301233+ 83 Linux
/dev/mmcblk0p9 267 467 1614501 83 Linux
  1. Some times after partitioning eMMC device files(/dev/mmcblk0p2, /dev/mmcblk0p3 etc) doesn’t appear and mkfs utility fails to format the partition and firmware flashing fails.
I used partprobe after partitioning eMMC but with not help. :frowning:
eMMC memory issue
First partition of the eMMC is of type “Win95 FAT32 (LBA)”
We are not formatting this partition and using it as raw.
There are 3 copies of MLO, 2 copies of u-boot.img, uImage and dtb in the that partition.
After trying multiple time flashing using dd, uImage first copy memory area is corrupted and board complains the image in that partition is corrupted.
Now if eMMC is having controller handling wear leveling and error correction mechanism then how memory area where kernel is stored is corrupted?
Any suggestions/ideas/pointers to any of the mentioned problem?
You've run into:
CONFIG_MMC_BLOCK_MINORS=8
Oh that was the problem…I was referring JDEC spec and all :slight_smile:
Thank you very much for reply Mr. Nelson,
7 Partition problem solved :slight_smile:
Let me know if you have any suggestions for other problems.
One more questions,
blkid
/dev/mmcblk0p2: LABEL=“rootfs” UUID=“3bb8e52f-1434-4e04-9d76-a50d75380c39” TYPE=“ext4”
/dev/mmcblk0p5: LABEL=“recovery_rootfs” UUID=“5f8060da-b692-4278-9120-af0258579e12” TYPE=“ext4”
/dev/mmcblk0p8: LABEL=“logging” UUID=“72064afc-e114-4339-89cd-76725fedbc86” TYPE=“ext4”
/dev/mmcblk0p3: LABEL=“rootfs2” UUID=“0287571c-6965-4906-91d0-347ec26f7aea” TYPE=“ext4”
/dev/mmcblk0p7: LABEL=“firmware” UUID=“b812c1a2-12dc-4543-b4f5-1bfc5f4c4e0a” TYPE=“ext4”
/dev/mmcblk0boot0: LABEL=“logging” UUID=“72064afc-e114-4339-89cd-76725fedbc86” TYPE="ext4"
/dev/mmcblk0p6: LABEL=“database” UUID=“45b8786e-bcb2-457d-8796-e78f9188aa55” TYPE=“ext4”
Why is /dev/mmcblk0boot0 appears here, it doesn’t show up in fdisk -l output?
from where is this mysterious partition coming from?
Problem in short:
eMMC partition’s device files are not visible in /dev/ directory after partitiong using "sfdisk"
HI ,
I have put log of script here, any suggestions,
  • partition_emmc /dev/mmcblk0
  • DRIVE=/dev/mmcblk0
  • HEADS=255
  • SECTOR_SIZE=512
  • SECTORS_PER_TRACK=63
    + dd if=/dev/zero of=/dev/mmcblk0 bs=1M count=108
    108+0 records in
    108+0 records out
    + sync
    + dd if=/dev/mmcblk0 of=/dev/null bs=1M count=108
    108+0 records in
    108+0 records out
  • sync
  • blockdev --flushbufs /dev/mmcblk0
    • grepgrep+ bytes Disk
  • awk {print $5}
  • SIZE=3841982464
  • echo DISK SIZE - 3841982464 bytes
  • echo 3841982464 255 / 63 / 512 / p
  • dc
  • CYLINDERS=467.094
  • echo CYLINDERS - 467.094
    CYLINDERS - 467.094
  • sfdisk -R /dev/mmcblk0
    BLKRRPART: Device or resource busy
    sfdisk: This disk is currently in use.
Problem in short:
eMMC partition's device files are not visible in /dev/ directory after
HI ,
+ partition_emmc /dev/mmcblk0
+ DRIVE=/dev/mmcblk0
+ HEADS=255
+ SECTOR_SIZE=512
+ SECTORS_PER_TRACK=63
108+0 records in
108+0 records out
+ sync
108+0 records in
108+0 records out
+ sync
+ blockdev --flushbufs /dev/mmcblk0
+ + grepgrep+ bytes Disk
+ awk {print $5}
+ SIZE=3841982464
+ echo DISK SIZE - 3841982464 bytes
+ echo 3841982464 255 / 63 / 512 / p
+ dc
+ CYLINDERS=467.094
+ echo CYLINDERS - 467.094
CYLINDERS - 467.094
+ sfdisk -R /dev/mmcblk0
+ [ 1 -ne 0 ]
+ + + grepawk /dev/mmcblk0 {print $3}
mount
+ mntpoint=/media/mmcblk0p8
/media/mmcblk0p6
/media/mmcblk0p7
/media/mmcblk0p5
+ echo unmounting /media/mmcblk0p8
+ umount /media/mmcblk0p8
+ echo unmounting /media/mmcblk0p6
+ umount /media/mmcblk0p6
+ echo unmounting /media/mmcblk0p7
+ umount /media/mmcblk0p7
+ echo unmounting /media/mmcblk0p5
+ umount /media/mmcblk0p5
+ sfdisk --force --in-order --Linux -H 255 -S 63 -C 467.094 /dev/mmcblk0 -uM
Checking that no-one is using this disk right now ...
OK
Disk /dev/mmcblk0: 467 cylinders, 255 heads, 63 sectors/track
sfdisk: ERROR: sector 184348 does not have an msdos signature
sfdisk: /dev/mmcblk0: unrecognized partition table type
Old situation:
sfdisk: No partitions found
New situation:
Units = mebibytes of 1048576 bytes, blocks of 1024 bytes, counting from 0
   Device Boot Start End MiB #blocks Id System
/dev/mmcblk0p1 * 0+ 31 32- 32767+ c W95 FAT32 (LBA)
/dev/mmcblk0p2 32 231 200 204800 83 Linux
/dev/mmcblk0p3 232 431 200 204800 83 Linux
/dev/mmcblk0p4 432 3663 3232 3309568 5 Extended
/dev/mmcblk0p5 432+ 531 100- 102399+ 83 Linux
/dev/mmcblk0p6 532+ 591 60- 61439+ 83 Linux
/dev/mmcblk0p7 592+ 791 200- 204799+ 83 Linux
/dev/mmcblk0p8 792+ 2060 1269- 1299455+ 83 Linux
/dev/mmcblk0p9 2061+ 3663 1603- 1641471+ 83 Linux
Successfully wrote the new partition table
Re-reading the partition table ...
If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
+ sync
+ partprobe
Auto-mount of [/media/mmcblk0p5] successful
Auto-mount of [/media/mmcblk0p6] successful
Auto-mount of [/media/mmcblk0p7] successful
Auto-mount of [/media/mmcblk0p8] successful
Error: Error informing the kernel about modifications to partition
/dev/mmcblk0p5 -- Device or r.
Error: Failed to add partition 5 (Device or resource busy)
+ rm -rf /tmp/.a*
+ mdev -s
mount: mounting /dev/mmcblk0p1 on /media/mmcblk0p1 failed: Invalid argument
rm: can't remove '/tmp/.automount-mmcblk0p1': No such file or directory
mount: mounting /dev/mmcblk0p2 on /media/mmcblk0p2 failed: Invalid argument
rm: can't remove '/tmp/.automount-mmcblk0p2': No such file or directory
mount: mounting /dev/mmcblk0p3 on /media/mmcblk0p3 failed: Invalid argument
rm: can't remove '/tmp/.automount-mmcblk0p3': No such file or directory
mount: mounting /dev/mmcblk0p4 on /media/mmcblk0p4 failed: Invalid argument
rm: can't remove '/tmp/.automount-mmcblk0p4': No such file or directory
rm: can't remove '/tmp/.automount-mmcblk0p7': No such file or directory
rm: can't remove '/tmp/.automount-mmcblk0p8': No such file or directory
+ sync
+ mount
rootfs on / type rootfs (rw)
192.168.1.3:/nfsboot on / type nfs
(rw,relatime,vers=2,rsize=4096,wsize=4096,namlen=255,hard,nol)
proc on /proc type proc (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
none on /dev/pts type devpts (rw,relatime,mode=600)
tmpfs on /dev/shm type tmpfs (rw,relatime,mode=777)
tmpfs on /var/run type tmpfs (rw,relatime,mode=777)
tmpfs on /var/spool/cron type tmpfs (rw,relatime,mode=755)
tmpfs on /var/sftp type tmpfs (rw,relatime,mode=755)
+ [ 0 -ne 0 ]
+ echo Nothing is mounted on /dev/mmcblk0
+ RETRY=50
+ NO_OF_PARTITIONS=2
+ 2 != 10
./BAK_S99-flashfirmware: line 1: 2: not found
+ check_and_format_partition /dev/mmcblk0p2 rootfs
+ PARTITION=/dev/mmcblk0p2
+ LABEL=rootfs
+ MNTPNT=0
+ mount
+ grep /dev/mmcblk0p2
+ awk {print $3}
+ MNTPNT=
+ [ -n ]
+ [ -b /dev/mmcblk0p2 ]
+ mkfs.ext4 -L rootfs /dev/mmcblk0p2
mke2fs 1.42.8 (20-Jun-2013)
mkfs.ext4: No such file or directory while trying to determine hardware
sector size
+ check_and_format_partition /dev/mmcblk0p3 rootfs2
+ PARTITION=/dev/mmcblk0p3
+ LABEL=rootfs2
+ MNTPNT=0
+ mount
+ grep+ awk /dev/mmcblk0p3
{print $3}
+ MNTPNT=
+ [ -n ]
+ [ -b /dev/mmcblk0p3 ]
+ echo Cant find /dev/mmcblk0p3 partition
+ check_and_format_partition /dev/mmcblk0p5 recovery_rootfs
+ PARTITION=/dev/mmcblk0p5
+ LABEL=recovery_rootfs
+ MNTPNT=0
+ mount
+ grep /dev/mmcblk0p5+ awk {print $3}
+ MNTPNT=/media/mmcblk0p5
+ [ -n /media/mmcblk0p5 ]
+ echo /dev/mmcblk0p5 is mounted on /media/mmcblk0p5
+ [ -b /dev/mmcblk0p5 ]
+ echo Cant find /dev/mmcblk0p5 partition
+ check_and_format_partition /dev/mmcblk0p6 database
+ PARTITION=/dev/mmcblk0p6
+ LABEL=database
+ MNTPNT=0
+ mount
+ grep /dev/mmcblk0p6
+ awk {print $3}
+ MNTPNT=
+ [ -n ]
+ [ -b /dev/mmcblk0p6 ]
+ mkfs.ext4 -L database /dev/mmcblk0p6
/dev/mmcblk0p6 is mounted; will not make a filesystem here!
+ check_and_format_partition /dev/mmcblk0p7 firmware
+ PARTITION=/dev/mmcblk0p7
+ LABEL=firmware
+ MNTPNT=0
+ grep /dev/mmcblk0p7
+ mount
+ awk {print $3}
+ MNTPNT=/media/mmcblk0p7
+ [ -n /media/mmcblk0p7 ]
+ echo /dev/mmcblk0p7 is mounted on /media/mmcblk0p7
+ [ -b /dev/mmcblk0p7 ]
+ mkfs.ext4 -L firmware /dev/mmcblk0p7
/dev/mmcblk0p7 is mounted; will not make a filesystem here!
+ check_and_format_partition /dev/mmcblk0p8 logging
+ PARTITION=/dev/mmcblk0p8
+ LABEL=logging
+ MNTPNT=0
+ grep /dev/mmcblk0p8
+ awk {print $3}
+ mount
+ MNTPNT=/media/mmcblk0p8
+ [ -n /media/mmcblk0p8 ]
+ echo /dev/mmcblk0p8 is mounted on /media/mmcblk0p8
+ [ -b /dev/mmcblk0p8 ]
+ echo Cant find /dev/mmcblk0p8 partition
+ sed -r s/://g
+ cat /sys/class/net/eth0/address
+ MACADDRESS=7c669d19cce2
+ BASE_MOUNT_POINT=/mnt/7c669d19cce2
+ ROOTFS_MOUNT=/mnt/7c669d19cce2/rootfs
+ ROOTFS2_MOUNT=/mnt/7c669d19cce2/rootfs2
+ ROOTFS_RECOVERY_MOUNT=/mnt/7c669d19cce2/recovery_rootfs
+ DB_MOUNT=/mnt/7c669d19cce2/database
+ FIRMWARE_MOUNT=/mnt/7c669d19cce2/firmware
+ LOGGING_MOUNT=/mnt/7c669d19cce2/logging
+ echoAndLog mount all the partitions
+ echo mount all the partitions
+ logger -p 5 -t ./BAK_S99-flashfirmware mount all the partitions
+ [ ! -d /mnt/7c669d19cce2/rootfs ]
+ [ ! -d /mnt/7c669d19cce2/rootfs2 ]
+ [ ! -d /mnt/7c669d19cce2/recovery_rootfs ]
+ [ ! -d /mnt/7c669d19cce2/database ]
+ RETRY=50
+ [ 50 -ne 0 ]
+ [ ! -b /dev/mmcblk0p2 ]
+ echo ....Waiting till /dev/mmcblk0p2 appears retry=50
Anything fishy ?? If same partitioning command i run from command prompt it
works but not from script do you suggestion anything ?
Script looks as show below..
DRIVE="/dev/mmcblk0"
RFS1_PARTITION=${DRIVE}p2
RFS2_PARTITION=${DRIVE}p3
RECOVERYRFS_PARTITION=${DRIVE}p5
DATABASE_PARTITION=${DRIVE}p6
FIRMWARE_PARTITION=${DRIVE}p7
LOGGING_PARTITION=${DRIVE}p8
partition_emmc()
        DRIVE=$1
        HEADS=255
        SECTOR_SIZE=512
        #Clear the first 512KB of the disk to clear MBR
        dd if=/dev/zero of=${DRIVE} bs=1M count=108
        sync
        dd if=${DRIVE} of=/dev/null bs=1M count=108
        sync
        blockdev --flushbufs ${DRIVE}
        #Get the size of the disk
        SIZE=$(fdisk -l $DRIVE | grep "Disk" | grep bytes | awk '{print
$5}')
        echo "DISK SIZE - $SIZE bytes"
        #calculate the no of cylinders in the disk
        CYLINDERS=$(echo "$SIZE $HEADS / $SECTORS_PER_TRACK / $SECTOR_SIZE /
p" | dc )
        echo "CYLINDERS - $CYLINDERS"
        #Check if any of the partition is mounted, umount it if mounted.
        $(sfdisk -R ${DRIVE})
        if [ $? -ne 0 ];then
                mntpoint=$(mount | grep ${DRIVE} | awk '{print $3}')
                for i in $mntpoint ; do
                        echo "unmounting $i"
                        umount $i
                done
        else
                echo "Nothing is mounted on ${DRIVE}"
        fi
        #Partition drive
# sfdisk --force --in-order --Linux -H 255 -S 63 -C $CYLINDERS
${DRIVE} -uM <<-__EOF__
        sfdisk --force --in-order --Linux -H 255 -S 63 -C 467 ${DRIVE} -uM
<<-__EOF__
Stop with all the cylinders crap, it's not 2009 anymore and we "fixed"
x-loader/u-boot spl, with the boot from "63" location "years" ago...
        ,32,C,*
          1,32,C,* (now you have a 1Mb hole, which will work with
the bootloader..)
        ,200,L
        ,200,L
        ,E
        ,100,L
        ,60,L
        ,200,L
        ,1269,L
        __EOF__
# arg1 = partition
# arg2 = label
check_and_format_partition()
    PARTITION=$1
    LABEL=$2
        MNTPNT=0
        MNTPNT=$(mount | grep $PARTITION | awk '{print $3}')
        if [ -n "$MNTPNT" ]; then
            echo "$PARTITION is mounted on $MNTPNT"
        fi
    if [ -b $PARTITION ]; then
        mkfs.ext4 -L $LABEL $PARTITION
        #TODO : Find correct tunning parameter and set it.
        #tune2fs
    else
        echo "Cant find $PARTITION partition"
    fi
#Partition the eMMC
    partition_emmc $DRIVE
    sync
    blockdev --flushbufs $DRIVE
    partprobe
    rm -rf /tmp/.a*
    #Trigger the creation of the device files
    mdev -s
    sync
    mount
    if [ $? -ne 0 ]; then
                umount $i
            done
    else
    fi
    #Wait till mmcblk0pX partitions are available.
    RETRY=50
    NO_OF_PARTITIONS=2
    while (( $NO_OF_PARTITIONS != 10 )); do
        while (( [ $RETRY -ne 0 ] && [ ! -b "${DRIVE}p$i" ] )); do
           echo "....Waiting till $RFS1_PARTITION appears"
           RETRY=`expr $RETRY - 1`
           sleep 1
        done
    if [ $RETRY -eq 0 ];then
        echo "Error..Device files are not present"
        exit 1;
    fi
        NO_OF_PARTITIONS=`expr NO_OF_PARTITIONS + 1`
    done
    #Format the partitions
    check_and_format_partition $RFS1_PARTITION $RFS_STRING
    check_and_format_partition $RFS2_PARTITION $RFS2_STRING
    check_and_format_partition $RECOVERYRFS_PARTITION $RFS_RECOVERY_STRING
    check_and_format_partition $DATABASE_PARTITION $DATABASE_STRING
    check_and_format_partition $FIRMWARE_PARTITION $FIRMWARE_STRING
    check_and_format_partition $LOGGING_PARTITION $LOGGING_STRING
      MACADDRESS=`cat /sys/class/net/eth0/address | sed -r 's/://g'`
      BASE_MOUNT_POINT=/mnt/$MACADDRESS
      ROOTFS_MOUNT=$BASE_MOUNT_POINT/rootfs
      ROOTFS2_MOUNT=$BASE_MOUNT_POINT/rootfs2
      ROOTFS_RECOVERY_MOUNT=$BASE_MOUNT_POINT/recovery_rootfs
      DB_MOUNT=$BASE_MOUNT_POINT/database
      FIRMWARE_MOUNT=$BASE_MOUNT_POINT/firmware
      LOGGING_MOUNT=$BASE_MOUNT_POINT/logging
      echoAndLog "mount all the partitions"
      #Create mount point if it doesn't exist.
      if [ ! -d "$ROOTFS_MOUNT" ]; then
         mkdir -p $ROOTFS_MOUNT
      fi
      if [ ! -d "$ROOTFS2_MOUNT" ]; then
         mkdir -p $ROOTFS2_MOUNT
      fi
      if [ ! -d "$ROOTFS_RECOVERY_MOUNT" ]; then
         mkdir -p $ROOTFS_RECOVERY_MOUNT
      fi
      if [ ! -d "$DB_MOUNT" ]; then
         mkdir -p $DB_MOUNT
      fi
Hi Mr. Nelson,
Problem in short
I changed partitioning command but with help,
Here is my sfdisk commad,
#Partition drive
sfdisk --force --in-order --Linux ${DRIVE} -uM <<-EOF
1,32,C,*
,200,L
,200,L
,E
,100,L
,60,L
,200,L
,1269,L
Hi Mr. Nelson,
I made some progress,
mdev was auto-mounting /dev/mmcblk0* partitions, i changed following line in the mdev.conf file.
#mmcblk[0-9]p+[0-9]* root:root 660 */etc/mdev/mount.sh $MDEV
But i don’t understand why auto-mounting was creating problem,
Because before erasing the partition, I was checking if partition is mounted or not and if mounted i was umounting it.
Is it right change ?
Thank you
