Whats crack’n Vinay!! Looks to me like Wheezy.
Hey Will,
5: ff:P-O-- Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI
6: ff:P-O-- Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN
The L in P-O-L means loaded, so in the case above it’s telling you that the HDMI hasn’t been loaded. So you’ve successfully disabled it.
When you do this
“Another solution is also simple, just include the line “CAPE=ADAFRUIT-SP0” in /etc/default/capemgr file. Then reboot and all should work fine”
You’ll have to do both, disable the HDMI like you’ve done (if you want to use SPI1) and load the SPI dtbo like in the step above.
You should then see it loaded when you cat the slots. Below is what mine looks like (I have a few different things loaded, but you can see that the HDMI has been disabled and both SPI’s loaded)
root@beaglebone:/sys/devices# cd /sys/devices/bone_capemgr.*
root@beaglebone:/sys/devices/bone_capemgr.9# cat slots
0: 54:PF—
1: 55:PF—
2: 56:PF—
3: 57:PF—
4: ff:P-O-L Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G
7: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-SPI0-01
8: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-SPI1-01
9: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-UART1
10: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-UART4
11: ff:P-O-L Override Board Name,00A0,Override Manuf,AEI-UART5
12: ff:P-O-L Override Board Name,00A0,Override Manuf,bspm_P8_32_f
13: ff:P-O-L Override Board Name,00A0,Override Manuf,am33xx_pwm
14: ff:P-O-L Override Board Name,00A0,Override Manuf,bone_pwm_P9_16
check for ‘spidev1.x’ in /dev
e.g
root@beaglebone:~# cd /dev
root@beaglebone:/dev# ls
If spidev is in there, you successfully loaded the SPI
This is the version of linux I’m running on my BBB
root@beaglebone:~# uname -a
Linux beaglebone 3.8.13-bone79 #1 SMP Tue Oct 13 20:44:55 UTC 2015 armv7l GNU/Linux
