Jackd immediately failing with bus error
I have a Beaglebone audio cape installed on the 3.8.13-bone70 kernel. It runs fine from the perspective of using aplay, alsamixer and such, but Jackd crashes every time with a bus error when I try and run it.
root@beaglebone:~/jack2/linux/alsa# aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: EVM [DA830 EVM], device 0: AIC3X tlv320aic3x-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
jackd -R -d alsa -dhw:EVM -p256
jackdmp 1.9.11
Copyright 2001-2005 Paul Davis and others.
Copyright 2004-2014 Grame.
jackdmp comes with ABSOLUTELY NO WARRANTY
This is free software, and you are welcome to redistribute it
under certain conditions; see the file COPYING for details
JACK server starting in realtime mode with priority 10
Bus error
I need jack to run supercollider, unfortunately…
I gather from some forum posts that I need some extra kernel modules installed via the /etc/modules.conf file, but they problem is that those modules don’t seem to exist in the stock kernel from what I can gather looking at the /lib/modules tree. I am not sure what level driver the alsa tools like aplay are using, that jackd is not using, but I wish I could figure out a way for jack not to need that separate pathway into the cape device.
/etc/modules:
snd_soc_tlv320aic3x
snd_soc_davinci
snd_soc_davinci_mcasp
snd_soc_evm
root@beaglebone:~/jack2/linux/alsa# lsmod
Module Size Used by
arc4 1691 2
rt2800usb 13470 0
rt2800lib 41926 1 rt2800usb
rt2x00usb 9839 1 rt2800usb
rt2x00lib 35799 3 rt2x00usb,rt2800lib,rt2800usb
mac80211 424813 3 rt2x00lib,rt2x00usb,rt2800lib
cfg80211 354018 2 mac80211,rt2x00lib
rfkill 16672 1 cfg80211
g_multi 50407 2
libcomposite 15028 1 g_multi
omap_rng 4062 0
mt7601Usta 639170 0
Is there an existing prebuilt kernel that will fix this problem?
