Since I last brought up wifi on a BBB rev c apparently a new way has become standard for configuring wifi. connmanctl With a couple BBB rev C that I have run Wheezy on with Edimax USB wifi dongles receiving a DHCP ip v4 address after modifying /etc/network/interfaces. I’m trying to flash a jessie image on those same rev C BBBs and dongles and bring up wifi. I’ve tried all of these three images
bone-debian-8.4-lxqt-4gb-armhf-2016-05-13-4gb.img
and
BBB-blank-debian-8.5-lxqt-4gb-armhf-2016-06-19-4gb.img
and
bone-debian-8.5-iot-armhf-2016-06-19-4gb.img
Am I using the correct image? Did I miss some RTFM?
I just uncomment the flasher line in uEnv.txt and boot. No messing with holding buttons down anymore right? Seems to work.
With both images I get the following running connmanctl Which doesn’t look like what I’ve seen in threads here in the Google Groups BBB forum.
A quick ifconfig first
root@beaglebone:~# ifconfig
eth0 Link encap:Ethernet HWaddr 68:9e:19:8f:eb:2b
UP BROADCAST MULTICAST DYNAMIC MTU:1500 Metric:1
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:175
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:10720 errors:0 dropped:0 overruns:0 frame:0
TX packets:10720 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:826080 (806.7 KiB) TX bytes:826080 (806.7 KiB)
tether Link encap:Ethernet HWaddr 74:da:38:42:61:dd
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::8c3c:fbff:fec1:115d/64 Scope:Link
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
TX packets:43 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:11299 (11.0 KiB)
usb0 Link encap:Ethernet HWaddr 68:9e:19:8f:eb:20
inet addr:192.168.7.2 Bcast:192.168.7.3 Mask:255.255.255.252
UP BROADCAST MULTICAST MTU:1500 Metric:1
wlan0 Link encap:Ethernet HWaddr 74:da:38:42:61:dd
inet6 addr: fe80::76da:38ff:fe42:61dd/64 Scope:Link
TX packets:58 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:16845 (16.4 KiB)
root@beaglebone:~#
and the connmanctl
root@beaglebone:~# connmanctl
Error getting VPN connections: The name net.connman.vpn was not provided by any .service filesconnmanctlconnmanctl> enable wifi
Error wifi: Already enabled
scan wifi
services
agent on
Agent registered
scan wifi
services
quit
root@beaglebone:~#
disk size seems a bit odd? 144M available?
root@beaglebone:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 0 10M 0% /dev
tmpfs 99M 8.4M 91M 9% /run
/dev/mmcblk0p1 3.5G 3.2G 144M 96% /
tmpfs 247M 0 247M 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 247M 0 247M 0% /sys/fs/cgroup
tmpfs 50M 0 50M 0% /run/user/1000
tmpfs 50M 0 50M 0% /run/user/0
root@beaglebone:~# cat /etc/dogtag
BeagleBoard.org Debian Image 2016-06-19
