jffs2 support in kernel 3.2.28 with angstrom
hi all,
I’m trying to flash my filesystem to NAND in a BB revC5, with some problems. I’m running angstrom with kernel 3.2.28 and kernel 2.6.39.
When I try to mount the filesystem partition in the nand (/dev/mtdblock4) with kernel 3.2.28 $mount -t jffs2 /dev/mtdblock4 /mnt/nand
mount says that filesystem type ‘jffs2’ is unknown. But when I try the same exact command with kernel 2.6.39 it works fine. I would like to know if there is any issue related to support for jffs2 in 3.2.28. So far I have compiled 3.2.28 twice making sure jffs2 support is enabled and some MTD options are enabled too, but the problem with the mount command persists. I would like to know if there is any option or patch or tweak to apply to the kernel in order to get jffs2 recognized by mount and by kernel.
best regards,
Victor
