jSSC install problem on BBB Rev C Debian
I’m having problems using jSSC on my BBB Rev C running Debian. Has anyone successfully installed jSSC?? It doesn’t seem to be available using apt-get.
If you have it up & running, what procedure did you use to install it??
Thanks in advance.
It's packaged in "jessie"
https://packages.debian.org/jessie/libjssc-java
you can just package it from the IDE in the jar and use default jssc jar 2.8 version.
