KDB
hi all,
how to i am planning to debug on kdb on beaglebone.is it necessary to compile the host system also with kdb. or only target is enough.
hi all,
hi all,
i sucessfully connected he kgdb to the beaglebone.but can any body tell me how to debug and understand the debugging techniques
There is kdb and kgdb available in the kernel.
How did you connect? serial or network?
In case you connected through the serial I guess you will use your console as soon as you enter kdb/kgdb. The easiest way to enter kdb would be to let your target panic.
What would you like to debug?
Did you have a look here[1]?
Robert
[1] Using kgdb, kdb and the kernel debugger internals
