I tried cross-compile.
There was a error “not find arch/armconfigs/omap3_beagle_defconfig”.
So I tried
make ARCH=arm CROSS_COMPILE=arm-linux- omap2plus_defconfig
I asked where is your root file system located, and not about rebuilding it.
Telling by the history[1] I guess he already has a prebuilt root FS and just wants to compile a new kernel configuration. So in my opinion there is no relevance either in the root FS location nor building the root fs. But I might be wrong.
Sorry for the little explanation.
I was, “Build an Ubuntu root file system with RootStock” according to article, I made the SD card of Ubuntu.
And it works fine.
The first partition
MLO
boot.scr
uEnv.txt
uImage
uInitrd
The second partition
There is rootfilesystem.
I was in the process of following.
ln -s arm-linux-gnueabi-gcc arm-linux-gcc
and another is the same
I want to control the pinmux from the kernel. It rebuilded the kernel.
So,I just swaped uImage to rebuild the kernel.
Location stopped, but maybe in the init process of the root file system, modified only uImage.
