Kernel 3.8 install
OK, I've gotten and built the 3.8 kernel for BeagleBone. Now how do I
install the thing? Hopefully there's a web page to guide the process.
John
John,
Taken from the beagle kernel github:
copy over uImage and am335x-bone.dtb to /boot
Setup your uEnv depending on if you are using Angstrom or a vanilla u-boot as specificed here:
https://github.com/beagleboard/kernel/tree/3.8
Then boot. You may have an old u-boot which doesn't support devicetree, in which case you will have to recompile that too with the am335x config.
Hey Jack,
I found that page but it doesn't seem to handle everything. Maybe a
dumb question but what IS the kernel, uImage or vmlinux?
I based my install effort last night on this page
http://beagleboard.org/linux
That process got the kernel and accessories compiled, mostly to
INSTALL_MOD_PATH but doesn't cover installation. I set INSTALL_MOD_PATH to
/home/jgd/BeagleBone_Dev/BeagleBone_3.8/kernel/deploy
I'm entertaining the notion of modifying Jack's tools/install.sh to fit
this version.
I did a little reverse-engineering on Jack's install script, read
README.md and came up with the following (from my log):
cd kernel
cp ../configs/beaglebone .config
make uImage dtbs (use my makeall.sh script)
cd /home/jgd/BeagleBone_Dev/BeagleBone_3.8/kernel/kernel/arch/arm/boot
copy over uImage to /boot  (/media/BEAGLE_BONE)
cd dtb
copy am335x-bone.dtb to /boot (/media/BEAGLE_BONE)
Edit uEnv.txt and add the following for the angstrom u-boot 2012.10:
devtree=/boot/am335x-bone.dtb
dtboot=run mmcargs; ext2load mmc ${mmcdev}:2 ${kloadaddr} ${bootfile} ;
ext2load mmc ${mmcdev}:2 ${fdtaddr} ${devtree} ; bootm ${kloadaddr} -
${fdtaddr}
uenvcmd=run dtboot
optargs=consoleblank=0
# Install kernel on the linux partition
cd /home/jgd/BeagleBone_Dev/BeagleBone_3.8/kernel/deploy/kernel/rootfs
$ tar -cvzf linux_3.8_kernel_tar.bz *
$ move tar to /root (/media/Angstrom-Cloud9-)
sudo mv linux_3.8_kernel.tar.bz /media/Angstrom-Cloud9-
cd /media/Angstrom-Cloud9-
sudo tar -xvf linux_3.8_kernel.tar.bz
sudo rm linux_3.8_kernel.tar.bz
$ dismount the card and boot.
The tar contained the contents of /lib/firmware and /lib/modules
I think that I should have deleted the contents of those two directories
before un-taring because both contained stuff not in the tar, stuff left
over from 2.8 I'm assuming.
This made a bootable card but it's strange. uname -a reports
3.2.33-psp26.1
and all three SPI devices are enumerated in /dev but now my test program
locks up even at 128 byte transfer. This time on the scope I see one
read cycle before lockup. Before I'd see the *chip_select go low and
sometimes a single clock cycle would appear before lockup.
If the above is correct then the DMA is still broken.
A critique of the above process is most welcome.
John
<snip>
I did the same procedure this morning except that before untaring the
contents of /lib/modules and /lib/firmware, I deleted all the previous
contents.
THIS TIME I get a system that uname -a reports as
Linux Maggie 3.2.33-psp26.1 #29 Fri Mar 8 01:43:31 EST 2013 armv7l GNU/Linux
The /dev/spi* are gone. There is a whole mess of spi-related files and
directories in /sys. find . -name 'spi*' -print returns 24 different
items. I'm just getting started exploring but so far nothing has done
anything when I tried to either open it or echo 1 to it or read it.
What a mess.
Anyone have any ideas?
John
I usually run:
#make the kernel and its modules, build the compressed image with the
proper address
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- ZRELADDR=0x80008000
uImage modules
#Copy the compiled kernel image to the boot directory of the
beaglebone, I usually change the name to something useful
sudo cp ${KSRC}/arch/arm/boot/uImage
/media/Angstrom-Cloud9-/boot/uImage-<version>-notes
#Save the old uImage, or delete it if it was a sym link
sudo mv uImage uImage-old
#Link your new kernel image to uImage
sudo ln -s uImage-<version>-notes uImage
Install your modules
sudo make ARCH=arm CROSS_COMPILE=arm-linux-gnueabi- modules_install
INSTALL_MOD_PATH=/media/Angstrom-Cloud9-
You'll need to replace /media/Angstrom-Cloud9- with your beagle bone
root dir if it's different.
The modules_install target should take care of the placement and
depmod for you. I'm guessing you remembered to enable SPI in the
config process. Forgetting modules_install made my SPI devices not
show up because spidev was compiled as a module.
-Jon
I usually run:
proper address
uImage modules
uImage goes on the VFAT partition, right? So linking isn't allowed.
Other than the ln issue, I did exactly your procedure. Put it in a
script just to be sure I got everything right.
There wasn't any config process but I checked kernel/kernel/.config to
make sure SPI was turned on. I can tell there is something happening
because I see a single toggle of the *CS line during boot, just like I
did with 2.8 kernel.
I did not get any devices in /dev/spi*. Are you having success in that
area?
One thing I did notice was something having to do with this new Device
Tree. In kernel/kernel/arch/arm/boot/dts, the file am335x-bone.dts had
SPI disabled. So I compiled it using dtc into a .dtb and copied that
over to the boot directory. One of the make files I was using earlier
concatenated this file on the end of uImage but apparently it can be
stand-alone too. I think.
In any event, I don't have any SPI that I can find.
Help!
John
I usually run:
proper address
uImage modules
No the partition labeled Angstrom-Cloud9- should be ext4 by default,
that's the root file system. It houses /boot which is where the uImage
should be placed.
you can run "make ARCH=arm menuconfig" to edit the config. You aren't
"supposed" to edit the file manually because it is overwritten without
warning.
area?
Yes, but I am running 3.2.21 and don't have device tree to contend with.
Help!
John
John DeArmond
Tellico Plains, Occupied TN
http://www.fluxeon.com <-- THE source for induction heaters
http://www.neon-john.com <-- email from here
http://www.johndearmond.com <-- Best damned Blog on the net
PGP key: wwwkeys.pgp.net: BCB68D77
For more options, visit http://beagleboard.org/discuss
You received this message because you are subscribed to the Google Groups "BeagleBoard" group.
To unsubscribe from this group and stop receiving emails from it, send an email to beagleboard+unsubscribe@googlegroups.com.
For more options, visit https://groups.google.com/groups/opt_out.
Your problems may lie in the device tree configuration. I've never
used it myself. Hopefully someone more experienced can chime in on
that subject.
-Jon
