Kernel 4.1 rc6-bone6: Ethernet not working
The config file is ok
But I don’t have IP?
eth0 Link encap:Ethernet HWaddr de:ad:be:ef:ca:fe
inet6 addr: fe80::dcad:beff:feef:cafe/64 Scope:Link
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:364 errors:0 dropped:0 overruns:0 frame:0
TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:24543 (23.9 KiB) TX bytes:4365 (4.2 KiB)
Interrupt:174
root@arm:~# dmesg | grep “phy 4a”
[ 6.291037] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 7.736772] net eth0: phy 4a101000.mdio:01 not found on slave 1
the led orange is ok and led green is blinking which is ok
I tried :
root@arm:~# /etc/init.d/networking restart
[ 185.246094] libphy: PHY 4a101000.mdio:01 not found
[ 185.251107] net eth0: phy 4a101000.mdio:01 not found on slave 1
[ 185.265139] net eth0: BQL enabled
[ 185.275592] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 185.275616] 8021q: adding VLAN 0 to HW filter on device eth0
[ 187.243856] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 187.243961] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
It works :
root@arm:~# ifconfig
inet addr:190.190.167.10 Bcast:190.190.255.255 Mask:255.255.0.0
RX packets:6329 errors:0 dropped:0 overruns:0 frame:0
TX packets:122 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1481867 (1.4 MiB) TX bytes:26160 (25.5 KiB)
Interrupt:174
The entire log of net :
[ 0.090282] Initializing cgroup subsys net_cls
[ 0.090305] Initializing cgroup subsys net_prio
[ 2.794392] audit: initializing netlink subsys (disabled)
[ 2.985118] cpsw 4a100000.ethernet: Detected MACID = 34:b1:f7:1b:02:c2
[ 6.282323] net eth0: initializing cpsw version 1.12 (0)
[ 6.285883] net eth0: phy found : id is : 0x7c0f1
[ 6.302341] net eth0: BQL enabled
[ 7.363496] using random self ethernet address
[ 7.363520] using random host ethernet address
[ 7.363532] using host ethernet address: 34:B1:F7:1B:02:C3
[ 7.364433] using random self ethernet address
[ 7.364443] using random host ethernet address
[ 7.364519] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
[ 7.729161] net eth0: initializing cpsw version 1.12 (0)
[ 7.731536] net eth0: phy found : id is : 0x7c0f1
[ 7.816588] net eth0: BQL enabled
[ 8.410985] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.803877] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 136.883463] cpsw 4a100000.ethernet eth0: Link is Down
[ 137.883895] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 185.243543] net eth0: initializing cpsw version 1.12 (0)
[ 185.246016] net eth0: phy found : id is : 0x7c0f1
Any idea ?
Ah... It's clearly working..
read: https://wiki.debian.org/NetworkConfiguration
I know how to configure IP address:
auto eth0
allow-hotplug eth0
iface eth0 inet static
address 190.190.167.10
netmask 255.255.0.0
gateway 190.190.255.253
But that didn’t work, any idea ? suggestion on where I am wrong ?
Thx,
did you set a name server ?
that ! Ok, No …
nano /etc/resolv.conf
By default I have :
nameserver 127.0.0.1
nameserver ::1
Ok, I will test this with :
nameserver 190.190.1.84
I saved it, reboot the beagle, and the content of the file changed :
Generated by Connection Manager
nameserver ::1
That my first time that the connection manager in a linux machine change my file !
dns-nameservers 190.190.1.84 >> /etc/network/interfaces
I tried on the official Beaglebone black, with the image :
bone-debian-8.0-console-armhf-2015-05-08-2gb.img
the kernel is :
root@arm:~# uname -a
Linux arm 3.14.41-ti-r63 #1 SMP PREEMPT Thu May 7 16:30:13 UTC 2015 armv7l GNU/Linux
eth0 Link encap:Ethernet HWaddr 1c:ba:8c:d9:4c:77
inet6 addr: fe80::1eba:8cff:fed9:4c77/64 Scope:Link
RX packets:475 errors:0 dropped:0 overruns:0 frame:0
TX packets:26 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:30795 (30.0 KiB) TX bytes:5017 (4.8 KiB)
Interrupt:56
still not working, my config :
auto lo
iface lo inet loopback
auto eth0
netmask 255.255.0.0
iface usb0 inet static
address 192.168.7.2
netmask 255.255.255.0
network 192.168.7.0
gateway 192.168.7.1
any idea ?
