I would like to set the screen resolution for the console and also stop console timeout.
From googling I read that I could change uEnv.txt to the following:
optargs=run_hardware_tests quiet video=omapfb:mode720x480@60 consoleblank=0
but this does not work.
The reason I want to change resolution is that the display goes to 1280x720 resolution when the actual physical resolution is 800x480.
This makes it hard to read text on the console. I don’t know who the manufacturers of these displays is trying to kid!
If I can get 800x480 that would be great, but I would be happy with 720x480. Audio is not used.
edid given below
Many thanks.
root@beaglebone:~# parse-edid /sys/class/drm/card0/card0-HDMI-A-1/edid
parse-edid: parse-edid version 2.0.0
parse-edid: EDID checksum passed.
EDID version 1 revision 3
Section “Monitor”
Block type: 2:0 3:fd
Block type: 2:0 3:fc
Identifier “32V3H-H6A”
VendorName “RTK”
ModelName “32V3H-H6A”
HorizSync 24-60
VertRefresh 50-75
Max dot clock (video bandwidth) 110 MHz
DPMS capabilities: Active off:no Suspend:no Standby:yes
Mode “1280x720” # vfreq 60.000Hz, hfreq 45.000kHz
DotClock 74.250000
HTimings 1280 1390 1430 1650
VTimings 720 725 730 750
Flags “+HSync” “+VSync”
EndMode
Mode “720x480” # vfreq 59.940Hz, hfreq 31.469kHz
DotClock 27.000000
HTimings 720 736 798 858
VTimings 480 489 495 525
Flags “-HSync” “-VSync”
EndMode
EndSection
