Kernel Configuration
Hi there,
Its been a long while since I played with embedded linux and back in
the day I was using PC104 386 boards so development was much simpler.
I have a beagleboard and have read various faq's, forums and how-to's
and tried installing OE with some success but ran into Ubuntu problems
(using 9.10). I then put it on the shelf for a month and am now back
it. Sorry for the long preamble. Ultimately, what I want to do is
use an existing stable angstrom console kernel and config the kernel
to include support for a CDMA usb stick. I'm pretty sure what I need
to be configured in the kernel for that to work.
My question is: for what I want to do (reconfigure existing kernel)
is OE the best way to go or can I get by with a simpler CodeSourcery
setup? I'm a little confused about the differences between the two.
Please clarify if I have this correct:
- OE is a complete toolchain used to build an entire distribution with
almost complete control over what gets packaged.
- Codesourcery Lite is also a toolchain but is more limited in scope,
but is probably better to use for actually compiling and debugging C, C
++ programs to run on the arm processor.
Am I completely out to lunch?
Appreciate all of your help.
Willem
setup?
One very big difference is that OE not only provides you a cross-compiler it also fetches and patches the kernel (among thousands of other programs) with a set of patches you don't want to live without. OE can provide you a full system with bells and whistles ready to be used on your Beagle, but you can also use it just to get you a decent kernel source which you can compile with a compiler whichever you choose; even CodeSourcery GCC.
Thanks Antti. With ARM and new drivers this is probably a very useful
feature.
I think you are comparing two things which are really in completely different
categories.
Codesourcery Lite is a C/C++ compiler toolchain; it includes a compiler, a
linker, a C library and a debugger (and some other random stuff).
OE is a set of tools used to product a full Linux distribution; this
is essentially
a large package of script for building various components. One of the components
that OE can build is a C compiler toolchain.
OE is probably a more complete product to achieve what you are doing.
Benno
Thanks Ben,
That is more or less what I thought. I wasn't exactly sure if CS also
built the whole distribution
and likewise if OE included the compiler toolchain. I guess that
settles it - OE it is. Hopefully Ubuntu 9.10 plays nicely. Now I
need to figure out what IDE I want to use: eclipes perhaps. I used
one about 5 years ago, I think it was called something like antigua or
something like that - I remember the icon was like a horses head. It
was a good ide.
Cheers,
Thanks Ben,
was a good ide.
http://projects.gnome.org/anjuta/index.shtml
Philip
If you are only interested to reconfigure/rebuild/develop the kernel a lot, you might like to have a look to
http://elinux.org/BeagleBoardLinuxKernel
Best regards
Dirk
