kernel hangs up after uncompressing linux
I am trying to build a new kernel image using arm-none-linux-gnueabi-
toolchain. I built the Linux Kernel 2.6.32 , after this i formatted
and created partitions in my
SD Card wherein i copied the uImage into the first partition of the SD
Card. Now when i bootup the board, then during the time of starting
kernel, i get the following
message:
## Booting kernel from Legacy Image at 80200000 ...
   Image Name: Linux-2.6.32.9-g049a746-dirty
   Data Size: 1919772 Bytes = 1.8 MB
   Load Address: 00008000
   Entry Point: 00008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
  OK
  Starting Kernel .........
  Uncompressing
Linux .........................................................................
  .............................................................done,
booting the kernel.
  after this is hangs
  Thanks and regards
  Ravi
Could you send your bootargs? It may caused by bootargs.
Yan
the serial output has changed from ttyS to ttyO in the recent
kernels..
Change it in uboot..
Not exactly in u-boot, but in bootargs. Probably you can change it in boot.scr.
Thank you,
Johnson
It may be due to DefConfig file selected during the kernel build process…I also faced the same,plz follow the following link:
http://groups.google.com/group/beagleboard/browse_thread/thread/c8a342126783a96e/f36bbf9772bc3676?hl=en&lnk=gst&q=Kernel+Hangs+while+starting#f36bbf9772bc3676
Danke,
Rajiv.
To be precise, it is ttyO2, instead of ttyS2.
Thank you,
Johnson
