Kernel Panic in beagle bone black
Hi All,
Am newbi to beaglebone black,am trying too boot from SD Card when i ever it boots it hangs with a kernel panic
here is the details of it
mmc0 is current device
micro SD card found
SD/MMC found on device 0
743 bytes read in 7 ms (103.5 KiB/s)
Running uenvcmd …
103 bytes read in 22 ms (3.9 KiB/s)
6840168 bytes read in 1153 ms (5.7 MiB/s)
84819 bytes read in 89 ms (930.7 KiB/s)
Using Device Tree in place at 88000000, end 88017b52
Starting kernel …
[ 3.312661] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 3.489443] remoteproc1: failed to load rproc-pru0-fw
[ 3.500714] remoteproc1: request_firmware failed: -2
[ 3.510872] pru-rproc 4a334000.pru0: rproc_boot failed
[ 3.523639] remoteproc2: failed to load rproc-pru1-fw
[ 3.529862] remoteproc2: request_firmware failed: -2
[ 3.535532] pru-rproc 4a338000.pru1: rproc_boot failed
[ 3.560964] cpu cpu0: cpu0 clock notifier not ready, retry
[ 3.741913] sr_init: platform driver register failed for SR
[ 3.769513] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
am really dont know wat is wrong ?
What did you pass as "root" to the kernel?
That is a strong indication you did not set up the rootfs partition on the sdcard correctly. First thing: get a stable build image.
Use the RCN image-builder scripts to create an sdcard image and then flash it to an sdcard. See instructions at:
https://github.com/beagleboard/image-builder
More info:
  • If you have a BBB v3 then use 4gb image (for debian that is bone-debian-7.6-lxde-4gb-armhf…), all other BBB versions use the 2gb iimage.
  • Start with the debian 7.6 rootfs until you REALLY understand what you’re doing.
  • To understand the mapping between the rootfs and the flash image look at the generated script in deploy/gift_wrap_final_images.sh
  • There is a lot of stale info about building the BBB. image-builder is the best and most up-to-date starting point for BBB work.
Dave
