I'm trying to compile a custom kernel (linux-omap-psp-2.6.32) using
openembedded. I successfully run
bitbake -c menuconfig virtual/kernel
bitbake -c compile virtual/kernel ; bitbake -c deploy virtual/kernel
bitbake base-image
Then I copied the image (the kernel image I used is
uImage-beagleboard.multi-config-cpuidle) into my sd card and booted
the board. But if I try to power the board only through usb, I obtain
the following kernel panic:
[ 16.674591] Unable to handle kernel NULL pointer dereference at
virtual address 00000014
[ 16.682739] pgd = c0004000
[ 16.685455] [00000014] *pgd=00000000
[ 16.689056] Internal error: Oops: 5 [#1] PREEMPT
[ 16.693695] last sysfs file:
[ 16.696685] Modules linked in:
[ 16.699768] CPU: 0 Tainted: G W (2.6.32 #0)
[ 16.705017] PC is at musb_interrupt+0x9f8/0xbb8
[ 16.709594] LR is at musb_interrupt+0x9e4/0xbb8
[ 16.714141] pc : [<c033e794>] lr : [<c033e780>] psr: 600001d3
[ 16.714141] sp : c0625ea0 ip : c0625ed8 fp : 000000f0
[ 16.725677] r10: 00000000 r9 : 00000099 r8 : 00000009
[ 16.730926] r7 : 00000000 r6 : cf82f108 r5 : 00000001 r4 : 00000000
[ 16.737487] r3 : 00000000 r2 : 00000000 r1 : fa0ab000 r0 : cf82f108
[ 16.744049] Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM
Segment kernel
[ 16.751586] Control: 10c5387d Table: 80004019 DAC: 00000017
[ 16.757354] Process swapper (pid: 0, stack limit = 0xc06242f0)
[ 16.763214] Stack: (0xc0625ea0 to 0xc0626000)
[ 16.767608] 5ea0: c0625ed8 00000002 2b971b6d 00000000 2b4e76c8
cf82f108 60000153 cf8a1940
[ 16.775817] 5ec0: c0624000 0000005c 00000000 00000000 c066c1c0
c033e9b8 c0625f08 cf8a1940
[ 16.784057] 5ee0: c0639550 c00a3b54 00000000 cf8a1940 c0639550
0000005c 00000002 00000001
[ 16.792266] 5f00: c0624000 0000001f 00000000 c00a5c4c 0000005c
00000000 c0670bb8 c003b074
[ 16.800506] 5f20: 00000000 ffffffff fa200000 c003bb44 00306dc4
00000000 00306dc4 00000000
[ 16.808715] 5f40: 00000003 00000003 c0670bb8 c0670c98 c0670c9c
411fc083 0000001f 00000000
[ 16.816955] 5f60: 3b9ac9ff c0625f78 c004c4c4 c004c4d0 60000053
ffffffff 00000000 00306dc4
[ 16.825164] 5f80: 00000002 2b971b6d 00000002 2b66ada9 c062a9f0
c0627fe0 c062a920 c06c43b4
[ 16.833404] 5fa0: 8002f234 c0385644 c06701cc c0624000 c0627fe0
c0627e84 c06701cc c003cfa4
[ 16.841613] 5fc0: 00000000 c06b73a0 c0670190 c0031010 c0627e78
c0008984 c0008498 00000000
[ 16.849853] 5fe0: 00000000 c0031010 10c53c7d c0670220 c0031414
80008034 00000000 00000000
[ 16.858093] [<c033e794>] (musb_interrupt+0x9f8/0xbb8) from
[<c033e9b8>] (generic_interrupt+0x)
[ 16.867370] [<c033e9b8>] (generic_interrupt+0x64/0x98) from
[<c00a3b54>] (handle_IRQ_event+0x)
[ 16.876739] [<c00a3b54>] (handle_IRQ_event+0xac/0x1ec) from
[<c00a5c4c>] (handle_level_irq+0x)
[ 16.886108] [<c00a5c4c>] (handle_level_irq+0xbc/0x148) from
[<c003b074>] (asm_do_IRQ+0x74/0x9)
[ 16.894866] [<c003b074>] (asm_do_IRQ+0x74/0x98) from [<c003bb44>]
(__irq_svc+0x44/0xa8)
[ 16.902893] Exception stack(0xc0625f30 to 0xc0625f78)
[ 16.907989] 5f20: 00306dc4
[ 16.916198] 5f40: 00000003 00000003 c0670bb8 c0670c98 c0670c9c
[ 16.924438] 5f60: 3b9ac9ff c0625f78 c004c4c4 c004c4d0 60000053 ffffffff
[ 16.931091] [<c003bb44>] (__irq_svc+0x44/0xa8) from [<c004c4d0>]
(omap3_enter_idle+0x108/0x14)
[ 16.939849] [<c004c4d0>] (omap3_enter_idle+0x108/0x140) from
[<c0385644>] (cpuidle_idle_call+)
[ 16.949401] [<c0385644>] (cpuidle_idle_call+0xa4/0x184) from
[<c003cfa4>] (cpu_idle+0x58/0xb8)
[ 16.958068] [<c003cfa4>] (cpu_idle+0x58/0xb8) from [<c0008984>]
(start_kernel+0x26c/0x2d8)
[ 16.966369] [<c0008984>] (start_kernel+0x26c/0x2d8) from
[<80008034>] (0x80008034)
[ 16.973999] Code: e3530003 13a02000 05963078 05933018 (05d33014)
[ 16.980194] ---[ end trace 2dcfe4fde02b5c19 ]---
[ 16.984863] Kernel panic - not syncing: Fatal exception in interrupt
I knew that this could be an issue related to insufficient power
provided by usb, so I powered the board via external vcc, and it
successfully boots.
The problem is that, whenever I attach the usb, I obtain a similar kernel panic:
Unable to handle kernel NULL pointer dereference at virtual a4
[ 41.776611] pgd = c0004000
[ 41.779327] [00000014] *pgd=00000000
[ 41.782928] Internal error: Oops: 17 [#1] PREEMPT
[ 41.787658] last sysfs file:
/sys/devices/platform/mmci-omap-hs.0/mmc_host/mmc0/mmc0:aaaa/bloe
[ 41.797973] Modules linked in: minix
[ 41.801574] CPU: 0 Tainted: G W (2.6.32 #0)
[ 41.806854] PC is at musb_interrupt+0x9f8/0xbb8
[ 41.811401] LR is at musb_interrupt+0x9e4/0xbb8
[ 41.815979] pc : [<c033e794>] lr : [<c033e780>] psr: 600001d3
[ 41.815979] sp : c0625ea0 ip : c0625ed8 fp : 000000f0
[ 41.827514] r10: 00000000 r9 : 00000099 r8 : 00000009
[ 41.832763] r7 : 00000000 r6 : cf82f108 r5 : 00000001 r4 : 00000000
[ 41.839324] r3 : 00000000 r2 : 00000000 r1 : fa0ab000 r0 : cf82f108
[ 41.845886] Flags: nZCv IRQs off FIQs off Mode SVC_32 ISA ARM
Segment kernel
[ 41.853393] Control: 10c5387d Table: 8fb54019 DAC: 00000017
[ 41.859191] Process swapper (pid: 0, stack limit = 0xc06242f0)
[ 41.865051] Stack: (0xc0625ea0 to 0xc0626000)
[ 41.869415] 5ea0: c0625ed8 0000001c 12ab9672 00000000 12785ead
[ 41.877655] 5ec0: c0624000 0000005c 00000000 00000000 c066c1c0
[ 41.885864] 5ee0: c0639550 c00a3b54 00000000 cf8a1940 c0639550
[ 41.894104] 5f00: c0624000 0000001f 00000000 c00a5c4c 0000005c
[ 41.902313] 5f20: 00000000 ffffffff fa200000 c003bb44 00051f2d
00000000 00051f2d 00000000
[ 41.910552] 5f40: 00000003 00000003 c0670bb8 c0670c98 c0670c9c
[ 41.918762] 5f60: 3b9ac9ff c0625f78 c004c4c4 c004c4d0 60000053
ffffffff 00000000 00051f2d
[ 41.927001] 5f80: 4cf3859f 116d8a80 4cf3859f 11686b53 c062ab10
[ 41.935211] 5fa0: 8002f234 c0385644 c06701cc c0624000 c0627fe0
[ 41.943450] 5fc0: 00000000 c06b73a0 c0670190 c0031010 c0627e78
[ 41.951660] 5fe0: 00000000 c0031010 10c53c7d c0670220 c0031414
[ 41.959899] [<c033e794>] (musb_interrupt+0x9f8/0xbb8) from
[ 41.969207] [<c033e9b8>] (generic_interrupt+0x64/0x98) from
[ 41.978546] [<c00a3b54>] (handle_IRQ_event+0xac/0x1ec) from
[ 41.987915] [<c00a5c4c>] (handle_level_irq+0xbc/0x148) from
[ 41.996673] [<c003b074>] (asm_do_IRQ+0x74/0x98) from [<c003bb44>]
[ 42.004730] Exception stack(0xc0625f30 to 0xc0625f78)
[ 42.009796] 5f20: 00051f2d
[ 42.018035] 5f40: 00000003 00000003 c0670bb8 c0670c98 c0670c9c
[ 42.026245] 5f60: 3b9ac9ff c0625f78 c004c4c4 c004c4d0 60000053 ffffffff
[ 42.032928] [<c003bb44>] (__irq_svc+0x44/0xa8) from [<c004c4d0>]
[ 42.041687] [<c004c4d0>] (omap3_enter_idle+0x108/0x140) from
[ 42.051239] [<c0385644>] (cpuidle_idle_call+0xa4/0x184) from
[ 42.059906] [<c003cfa4>] (cpu_idle+0x58/0xb8) from [<c0008984>]
[ 42.068206] [<c0008984>] (start_kernel+0x26c/0x2d8) from
[ 42.075836] Code: e3530003 13a02000 05963078 05933018 (05d33014)
[ 42.082000] ---[ end trace ee02d25607460bb0 ]---
[ 42.086639] Kernel panic - not syncing: Fatal exception in interrupt
It seems to be an musb-interrupt issue. Is there any kernel
configuration that is missed?
Thanks for help!
Daniele
